ej25
Old Sep 25, 2004 | 07:14 AM
Jejunum's Avatar
Originally Posted by Southerland
is the ej25 know for engine clatter....sounds like i like a lifter tap possible...or very small exhaust leak?
is known problems ?
check for bad timing belt tensioner if you hear a clatter coming from timing belt area (esp when cold).
Old Sep 25, 2004 | 11:29 AM
cabe's Avatar
Car Info: 99 subaru impreza 2.2L coupe
My mom's 98 legacy (ej25) has had engine clatter ever since I wrecked it. No idea what it's from, no performance loss as far as I can tell (I don't drive it a lot, but it's been 20K miles. Also, my brother in law's Audi 100 quattro just got it's engine clatter fixed and I think the diagnosis was something with the lifters.
Old Sep 27, 2004 | 01:27 PM
Kay95's Avatar
how many miles are on it?
and yes the 2.5 is known to tap and click more than other motors because it has solid lifter than need to be adjusted about 100k miles or so but if you have less than that it could be the tensioner
Old Oct 3, 2004 | 04:58 PM
Kay95's Avatar
does it ever go away? or can you hear it all the time but much more when cold
Old Oct 7, 2004 | 07:38 PM
Kay95's Avatar
other than noise is there any other problems?
Old Oct 12, 2004 | 11:54 PM
ImprezaRSX's Avatar
Big Baller
Car Info: 93 BG5, 00&01 GM6, 06LGT, 07STi
2.5 RS motors have roller rockers with no lifters. However they have two rocker ganged together which makes adjustments difficult and when the cams and valves start to wear it's real difficult to keep them quiet.
Mine clatter like crazy, but I installed COBB cams in mine.
Piston Slap is something that is popular also. With this H4 it'll sound like valve train noise, but it could be piston slap.
Old Oct 23, 2004 | 08:56 AM
AWDimprezaL's Avatar
its piston slap, EVERY 2.5 with over 50K has it, its not bad, in fact most all subaru engines will develop it, accept for the 2.2, because of the longer piston skirts, my master tech at my work says it will still go forever. so no worries
epyon08
Nov 5, 2014 08:18 AM
EJ_20
Jul 22, 2006 01:23 AM
keirnna
Feb 5, 2005 02:38 AM
stg2lgcy00
Aug 17, 2004 05:52 PM
