Crank Position Sensor Replacement
Old Jul 7, 2008 | 07:52 AM
redmomatt's Avatar
Car Info: 2004 Impreza 2.5 RS
Just a quick question about replacing the crank position sensor on an '04 Impreza RS. I've heard it's pretty easy to do, but the only manual I have to follow is the 2005 service manual. How different are the 2004 / 2005 engines and can I use the '05 manual as a guideline?
The '05 manual would have me take off the front V-belt and then the starter motor to get at the sensor. My only concern is getting the belt back on at the proper tension. Will I need a belt tensioner or can I safely use the method in the manual for replacement without it? Also, will I need any tools to correctly position/calibrate the sensor, or is it just a swap?
Thanks in advance for any advice!
PS. Anyone know where I get a service manual for an '04 Impreza? Both Haynes and Chilton don't seem to make one. Would I have to get one from a dealer?
Old Jul 7, 2008 | 08:13 AM
ipozestu's Avatar
Car Info: Broken Subarus
CPS is really easy to change. Right smack dab in the front/center of the block, behind the belts you'll see the sensor. There is a wire coming out of it. It should be held in place be one phillips head screw.
Old Jul 7, 2008 | 08:19 AM
ipozestu's Avatar
I have no idea why you'd have to remove the starter. You'll probably have to remove the belts. That's no biggie either. Just feel it out. Push the longest span on the belt with your finger get a fell for how hard you are pushing and take a look at the deflection in the belt. Is it 1/4" 1/2"? Generally with belts you want them tight enough so they don't slip. Too tight and they wear faster.
Old Jul 7, 2008 | 08:45 AM
redmomatt's Avatar
Thanks a lot for the info. It always seems more complicated reading those manuals sometimes.
Should I also disable the ignition system or can I change it without doing this? If so, is there a best way or could I just unplug the negative on the battery?
Thanks again!
Old Jul 7, 2008 | 09:19 AM
ipozestu's Avatar
Not necessary, but it's aways suggested that you remove the Neg terminal any time you perform work. It's safer to do so.
Old Jul 7, 2008 | 01:27 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
All you need is a 1/4" drive ratchet, ~8 to 10 inch extension, and a wobbly 10mm socket.
Old Jul 7, 2008 | 01:45 PM
ipozestu's Avatar
It was a 10mm. That's right.
RyanForbes
Jan 26, 2012 09:59 PM
not12listen
Mar 24, 2009 09:00 AM
cicciolina
Mar 20, 2006 02:40 PM
brandon shim
Sep 9, 2003 10:32 AM
sin3kal
Aug 4, 2003 01:15 PM
