cold air vs. ram air
Old May 6, 2003 | 03:11 PM
dangerousatom's Avatar
Car Info: 02-04R-STi PPG's FP-Green 391whp
Well I got a 02 RS with a Borla Headder, Randon Tech cat, and a Greddy EVO cat cack. "Sound is killer" It is an amasing system of free flowing art. It sounds great and my fule economy is up like 15-20% and Hp with the AEM short ram in ( a guess of 25-30 more that stock ) so in all it kicks butt in every way.......was also a very easy install to boot
Old May 6, 2003 | 03:25 PM
AEM (or any other brand) short rams do nothing. The AEM cold air intake, that runs through the fender, is ok, but not as good as Cobb or Gravelsport or Ganzflow.
Old May 6, 2003 | 03:34 PM
When you start modding, the total power gains tend to be more than the sum of the parts, but on any given car, a short ram that draws air from under the hood is less powerful than a true cold air intake.
Old May 6, 2003 | 04:03 PM
Turbo or no, it's hard to argue with thermodynamics. Warmer air contains less O2 for combustion than (relatively) cooler air does, regardless of what type of combustion is taking place or what is catalysing it.
Old May 6, 2003 | 05:21 PM
Velocity is a function of diameter, not length. Blow through a 12" piece of 1" tubing, and a 12" piece of 2" tubing to see why. Volume is the oposite, and rally cars need large volumes of air. Also, smaller intake component volume gives better throttle response, which is even more important in rallying than 2 horsepower.
Old May 6, 2003 | 05:29 PM
Okay, don't take my word for it. But do yourself a favor and email Shiv at Vishnu and ask why he won't tune cars with aftermarket intakes. He can explain it better than I can.
Old May 7, 2003 | 10:10 AM
ImprezaVA's Avatar
Car Info: 1998 Subaru Impreza L 2.2
I agree with BAN SUVS. Cold, denser air is always better than hot air coming from the engine bay, regardless of velocity. You mentioned something about rally cars using a short ram for velocity. True, but more hot air isn't better than say a little less cold air. If I remember correctly, an engine gains 1% HP, not 1 HP, from every 10 degrees dropped. Here is an opinion, but lets see if it floats. I don't know much about rallying, but wouldn't it make more sense to put the air supplier under the hood away from dirt, snow, water, and other debris just for that simple, yet important reason? I think BAN SUVS said the reason for a short ram on rally cars was for throttle response, but this was maybe another facet they considered.
-Charles-
Old May 7, 2003 | 04:15 PM
-Charles-
Good points, this finally reminds me of what I was forgetting earlier. Rally cars use ram air pods for 2 reasons:
1) Far less dirt, brush, rocks, small animals etc. under there.
2) Since power is determined by the 32mm, the warm air under there is perfectly capable of supporting the 300 or so horsepower they are making, so the cleaner warm air is better than the cooler 'dirty' air. Throttle response, while crucial to rallying, is probably less of a concern than thick billowing cluds of dust often seen in summertime west coast rallies.
Old May 7, 2003 | 06:59 PM
meebs's Avatar
Car Info: 09 WRX Hatch
could someone enlighten me on what a "short ram air intake" is?
when i think of ram-air. I'm thinking F1. And the reason for ram air is to try to generate a small ammount of presure. Why would you even bother when the turbo is generating far more pressure into the engine than you could ever hope for on a ram air intake.
