CEL: Suspect spark plugs, spark plug wires, or ignition coil
Old 10-20-2005, 10:47 AM
Former Vendor
DetailAddict's Avatar
Car Info: Evo X
Exclamation CEL: Suspect spark plugs, spark plug wires, or ignition coil
Okay I am getting CEL with 2/4 cylinder misfired. Well, first time with 2/4 and just this morning with 4 only. Suspecting bad plugs, wire, or even coil. Will start with the cheapest route first, plugs. I've seen a lot of people using NGK, but that sucker is expensive! I use Champion for my Protege and it seems to be okay. But even NGK has bunch of them and just wondering which to use.
And for spark plug wires and ignition coils, I have no idea. Help? Thanks!
Ignition Coil: Distributorless Ign.
Niehoff Ignition WA2155 $174.99
3 Month Limited Warranty
Borg Warner E765 $174.99
1 Year Limited Warranty
GP Sorensen 245324 $177.99
1 Year Replacement Warranty
Borg Warner CH74196 $83.99
Niehoff Ignition 1274196 $76.99
Borg Warner CH74196SP $74.99
Niehoff Ignition 1274196PS $68.99
Standard Motor Products 7577 $52.99
Bosch 09479 $48.99
Autolite Ignition 97066 $46.99
Lifetime Replacement Warranty
MagStar 234576Y $44.94
2 Year Replacement Warranty
MagStar 234576B $44.94
MagStar 234576R $44.94
Beck/Arnley 1756119 $39.99
3 Year Limited Warranty
Xact 4731 $27.48
OE Style
NGK 6741 OE Laser Iridium $17.99
NGK 4014 Laser Platinum $17.99
NGK 3764 Iridium IX $10.99
ACDelco 41801 $9.99
Champion 9001 $9.88
Autolite Ignition XP3923 $7.59
Champion 7346 $6.59
Bosch 4417 $5.99
Bosch 4303 $3.99
NGK 7092 G-Power Platinum $3.99
Autolite Ignition APP3923 $3.99
Bosch 4303 $3.99
Delco Rapidfire 5 $2.99
Autolite Ignition AP3923 $2.49
Champion 3071 $2.29
Bosch 4201 $2.29
NGK 5553 Standard $1.99
NGK 2756 V-Power $1.99
Autolite Ignition 3923 $1.39
Champion 346 $1.39
Bosch 7556 $1.09
Leo
DetailAddict is offline
Old 10-21-2005, 10:33 AM
Former Vendor
Car Info: Evo X
okay, picked up some NGK 2756 V-Power last night and cleared the CEL (I think it's still in the ECU). I'll drive around some more to see if it pops up again. If yes, I might consider chaning the fuel filter beofer I do the wires. I've read on scoobymods that fuel filter could cause CEL misfire as well. We'll see. So any idea on the spark plug wires and ignition coil?
Old 10-21-2005, 11:34 AM
AWDimprezaL's Avatar
do the plug wires next, then the coil pac
AWDimprezaL is offline
Old 10-21-2005, 03:11 PM
Former Vendor
Car Info: Evo X
yeah, I know, but any recommendation on which one to get? Thanks!
Vizzionz
04-07-2007 07:57 PM
breno58
05-21-2006 12:28 PM
Benjamin Tang
12-08-2003 07:11 PM
etal
05-23-2003 02:59 PM
burningphoenix
04-02-2003 02:25 PM
Quick Reply: CEL: Suspect spark plugs, spark plug wires, or ignition coil
