borla headers ARHHHHHHHHH!
Old Jan 11, 2004 | 11:22 AM
Kay95's Avatar
well a month ago i sent my set back because they didnt fit right and the brand new set i just tried to go on today and surprise surprise they didnt fit aswell
has any one else recieved two sets that didnt fit right?
Old Jan 11, 2004 | 03:41 PM
whitelegacy98's Avatar
what engine do you have and what didnt fit right?
Old Jan 11, 2004 | 04:46 PM
Defiantguy's Avatar
Car Info: 2004 Subaru WRX
ya more specifics please. My headers on my RS were a little stubborn but with a little force I got them in.
Old Jan 12, 2004 | 02:42 AM
Kay95's Avatar
oh ya 1.8
the holes where off by half an inch.
and even if i got them on it looks like the rear flange would be off by alot
Old Jan 12, 2004 | 04:36 AM
i2()N!N's Avatar
Car Info: 98'RS
when in dought hit it with a hammer
Old Jan 12, 2004 | 09:34 AM
I didnt think they made headers for the 1.8l are you sure they know what engine you have and arent sending ones designed for the EJ22 or EJ25. I could be WAY off here but just a thought
Old Jan 12, 2004 | 01:55 PM
Kay95's Avatar
i know what you are saying but i looked at the part numbers for the header for the 2.5 and it the same as the part number as the 1.8
it was the dual port
i dont want to force it on because if i do it will crack inside of a year and i dont want to try and take it off again
i forgot to mention that the collector on the passenger side is not even straight because the bottom pipe is pointing at the side of the collect wit the top pipe pointing directly at the collector exit
Old Jan 13, 2004 | 04:14 AM
Call Borla, they are very good about warranty replacement issues.
Old Jan 14, 2004 | 01:54 PM
Kay95's Avatar
it should not matter because subaru has the same PN for all NA engine except 97 and newer 2.2
and even if it was not the same PN the block on a 2.5 would be just a little bigger not smaller
Old Feb 7, 2004 | 07:51 PM
subyspecialist's Avatar
Car Info: 2000 2.5RS, soon to be sti
it isnt the block that is different, it is the heads. the 1.8, 2.0, 2.0 and 2.5 heads all have different spacing on them
Old Feb 7, 2004 | 08:59 PM
Kay95's Avatar
well its not the head it self but the head gasket that is different but that would only change center distance by no more than .030" but i know what you mean
Old Feb 7, 2004 | 11:02 PM
Kostamojen's Avatar
NASIOC Slut
YES I have had borlas on my 1.8 for like ages. Sold them to an RS owner a month or so ago.
The exhaust ports are the same. In fact, the exhaust ports are IDENTICLE on all EJ series engines exept the single port EJ22's made like between 98 and 01.
There is NO spacing difference, they should bolt up just the same.
Old Feb 8, 2004 | 08:09 AM
Kay95's Avatar
did you have to bend your headersa to fit?
Old Feb 8, 2004 | 10:18 PM
Kostamojen's Avatar
NASIOC Slut
Bend them? If you mean like move the long side a little to get it on, then everyone has to do that. If you mean actually drilling out new holes, then no.
