AIR INTAKE for 96 subaru Impreza
Old Jul 13, 2004 | 11:23 PM
Kostamojen's Avatar
NASIOC Slut
There really isnt one. Just get a 3" maf adapter and stick a cone where the airbox is if you want to do anything to it. Or, just remove the fender well intake silencer for now, that gets you about the most power you can get out of an intake for the 1.8. I run that with my 1.8, sometimes throw a cone filter on for kicks (noise) but it does squat for power.
Old Jul 15, 2004 | 01:55 PM
96Imprezadent's Avatar
Car Info: 1996 Impreza L
Arrow intake silencer
yeah man. take that bull out. you probly have no idea where it is, but i can help you with that. I have a 96 L with an EJ22 and i took mine out. Not much hp gain but the sound under hard acceleration is worth the 10 min it takes to do this. If your interested let me know. Sine00@aol.com
-Pete
Old Jul 17, 2004 | 12:12 AM
Kostamojen's Avatar
NASIOC Slut
98 should be fine, its not the paper MAF that the 99's had, its the rather robust metal wire one (I'm about 90% certain of this, double check to make sure though)
In any case, with a cone filter vs. the stock airbox, there really isnt any way to "blow the maf" unless something physically gets in there and nails the sensor. They do wear out over time of course.
Old Jul 17, 2004 | 03:20 PM
G.SUBRAMANIAM's Avatar
I bought a cold air intake kit with heat shield from Xcceleration.com
It bolted onto my 1997 Subaru Impreza 2.2 L,
which has old style intake
It feels like a mini-turbo, and kicks in at 1000 rpm
and the power is buttery smooth like a V6
My butt dyno shows it to be at least twice as effective as my underdrive pulley kit
Old Jul 18, 2004 | 01:31 PM
Myxalplyx's Avatar
Originally Posted by 96suBImPreZa
Having trouble finding an air intake for my 96 impreza. If you have come across any for a 1.8 the help would be great.
Try to make your own if you have some creativity. I purchased a Minnam intake off of someone a while back used for $25.00. Bought some rubber hoses and clamps, a maf adapter online and a K&N air filter. It works great and has some really good mid-range torque. 8lbs/ft (or so) extra in the midrange according to a dyno I did.
Top end fell off unfortunately to what the stock intake was. I need to retest it because I believe it pulled timing using 87 octane. I have since changed to 89 octane and top end was improved.
Notice how it suddenly ran richer above 5300rpm. Detonation! I don't have it anymore and like I said, timing has been restored according to my pocket logger. Throttle response is excellent as well. Cool cheap intake. All vents on hood are open. Intake is NEVER hot.
You could do it for less than $100 purchasing a used intake as well.
Cool air come in via WRX bonnet hood scoop purchased from MRT performance in Australia a while back. I think they have some here. It helps because I tested it in the 1/4 mile when my car was turbocharged. Only good for .1 - .2 in the 1/4 mile. I'm not sure if you have hood vents but if you do, this is an option.
Old Jul 24, 2004 | 09:21 AM
flvimpreza's Avatar
I have a MAF adapter and a intake if you want it. came from a 972.2L and it will fit your engine
Old Aug 6, 2004 | 12:13 AM
Shiseiji's Avatar
Car Info: 1993 Impreza L sedan
Here's my intake on my 93 1.8
https://www.i-club.com/forums/ongoing-projects-31/suzys-coming-right-along-68439/
I got it from www.procarparts.com
Looks like it's down to $38.66 now.
http://www.procarparts.com/store-det...=onlinestoreDB
Old Aug 6, 2004 | 11:21 AM
Kostamojen's Avatar
NASIOC Slut
Thats a good price. Its worth it just for the MAF adapter, filter and mounting material.
HungrySTI4V8
May 3, 2009 07:25 AM
HungrySTI4V8
Apr 18, 2009 08:27 AM
StankFootZ
Jul 6, 2004 12:02 PM
RyanH
Feb 19, 2003 05:37 PM
