aftermarket sparkplug wires
www.ptuning.com has Magnecors for $82.95.
What's wrong with the OEM wires? They are made specifically for your application, they are cheap, and they don't pop off the coil pack. Can't beat that. Besides, 99% of all our engine applications would never need different plug wires. Brian
read this web site
http://www.magnecor.com/magnecor1/main.htm
explains alot about ignition wires
$99 from boxer4racing.com
That explains the ignition wires they are trying to sell, try finding something on the OEM wires for Subaru, like "made and engineered for your motor from the manufacturer who knows best" All I'm saying is if you have a normal old Subaru without extensive mods, the OEM's are fine. Hell, even Pro Rally drivers stick with the OEM wires. Brian
the problem with the oem wires are that they burn out in about 25k miles and need to be replaced
the magnecors dont burn out because of the core material but then again they cost 4 time the oems
if you turn your radio to AM and can hear a tone than rises with the rpm of the engine the oems need replacing with what deppends on how long you are going to keep the motor because it should be atleast 100k to get your moneys worth out of the aftermarket wires
Benjamin Tang
Dec 8, 2003 07:11 PM
WRSport
Nov 25, 2002 05:06 PM
