Is 2.2L an Interference Motor?? and Tranny Question...
Old Nov 13, 2003 | 06:38 PM
ImprezaVA's Avatar
Car Info: 1998 Subaru Impreza L 2.2
This issue has been covered once or twice , but the 2.2 is not an Interference engine. If the timing belt snaps there probably won't be any internal damage. The 2.5 is an Interference engine.
The tranny and engine are quite robust in the 2.2's. That's why I bought one.
-Charles-
Old Nov 14, 2003 | 04:41 AM
ImprezaVA's Avatar
Some Help
These websites can be great assets for working on your Subaru. Since you're new to forum I don't know if you know about these or not.
www.nasioc.com
www.scoobymods.com
www.endwrench.com
The last is a great technical advice website. In fact, if you are changing out the t-belt here is some help:
http://www.endwrench.com/pdf/engine/...ReplaceW01.pdf
It's for 2.2 L single overhead cam engines.
-Charles-
Old Nov 14, 2003 | 05:43 PM
ej25turbo's Avatar
1.8 liter t-belt
can someone help me with my t-belt? I have it all torn apart but I need help lining up the timing marks on the cams and crank! where do you line them up? should they all be pointing up/ down ? please help cause I need to get this thing running by sunday! thanks
Old Nov 16, 2003 | 08:50 PM
Kay95's Avatar
well its late but still sunday...
if you still have the timing belt cover you will see a mark at the top of it and a mark on the pulley it self and just lineup and put the belt on a pull the pin for tensioner and put together but be careful not to pull to hard on the belt when puting around everything else
Wagon Joe
Oct 11, 2007 08:35 AM
crazy_sherm
Aug 3, 2004 07:21 PM
AWDForever
Nov 11, 2003 03:08 PM
mr. m
Oct 29, 2003 04:46 AM
