wierd rev.
Old Aug 24, 2005 | 08:32 AM
Flauntinghippo's Avatar
Car Info: 2005 WRX STI
wierd rev.
hi, i just bought an sti. its an '05 with like 6,000 miles. anyway, is there like a safe mode that the car can or will go into if you drive it too hard. recently my check engine light went on, then it turned off. and now it feels like it has less power, and when i let off the gas, the the rpm level floats a little before it drops. if anyone would have any ideas i would appreciate it.
thanks
Old Aug 24, 2005 | 09:06 AM
ish's Avatar
ish
I don't have an answer for your issue, but I see you are from Las Vegas. Just to let you know all the local las vegas subaru owners hang out over at www.flat4lv.com
but this site still has way more people and information on it. welcome.
Old Sep 11, 2005 | 05:40 PM
Boost Addict's Avatar
thanks
Sounds like a Limp Home Mode... I'd get the code pulled immediately!
Old Sep 11, 2005 | 06:46 PM
depdivr's Avatar
Car Info: 2005 Black WRX STI
thanks
Any mods yet?
I have had fuel cuts a couple of times, accompanied by a CEL. The most common issue was boost creep after installing a Blitz SBC with the stock turbo and waste gate. The other issue I had before installing new injectors was fuel cut because injector duity cycle was too high.
If you don't have any mods, I would get it into the shop asap.
Kostamojen
Aug 8, 2003 07:23 PM
aloose
Jun 8, 2003 04:30 PM
LiquidSubaru
Feb 25, 2003 06:41 PM
JunGdB
Jan 22, 2003 11:24 AM
