when to get a "built engine"
Old Feb 24, 2006 | 08:26 PM
lightningdriver's Avatar
Car Info: 06 wrc Blue STI
At what point are other owners finding it necessary to build the bottom end of their engines with, rods, pistons, sleaves etc.
I am looking for a reference point to know when I need to do this . Info on when I should start thinking about it and when you are definately past the limit of the stock internals would be helpful.
I plan to do drving spriited on the weekends and a few drag strip passes a month.
thank you .
Old Feb 26, 2006 | 04:50 AM
boomer's Avatar
Car Info: 99 2.5rs
If spirited driving and a few drag passes a month are all you will be doing you will not need rods, piston and the like. If you really need a # then between 400 and 450 but I'm sure some one will say to the opposite.
Old Mar 5, 2006 | 05:44 PM
i think i will thaink about it soon as i will have a gt35r kit and meth inj on the car in 3 weeks
Old Mar 5, 2006 | 09:01 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
I'd order up that built engine now for when you blow up you present engine in about 4 weeks.
Old Mar 9, 2006 | 05:03 PM
gruppe-s's Avatar
Hello,
I'm not sure if you have a WRX or STi but if you have an STi, I'd say that if you're making over 465 CHP and CTQ consistantly then you'll want to look at a built block for reliability. You can certainly make much more power on the stock block but I wouldn't plan on your engine lasting long at that power. The first things that you'll need to replace will be your pistsons (with forged units) and your bearings (preferably with coated race units). Our staged 2.5L built motors are designed to replace what's needed when it's needed. Another way to look at it is if you're running a TD06-20G / SZ49 / Green on a 91 all the time, you'll probably be OK. If you've got anything larger (GT30R, SZ55, GT35R), then you'll want look at a built block. This is contingent upon proper supporting mods and a good tune. Please let me know if you have any quesitons.
Thanks,
Geoff
Old Mar 10, 2006 | 12:17 AM
blinguskahn's Avatar
From: Leaving on a jet plane dont know if i'll be back..
Car Info: 05 STi White v2 8cm FP Red
+1 for Geoff's response (which i think i have seen 2190932842 times before).
Geoff, you forgot the FP Red in your list.
Old Mar 10, 2006 | 01:45 PM
gruppe-s's Avatar
Word, add that to the list w/ the GT30R sized turbos. Thanks Derrick.
Old Mar 12, 2006 | 07:50 PM
thanks
geoff , please send me a quote via email what it will cost to make that happen
directmetalsinc@yahoo.com
attn: andrew
thank you in advance
Old Mar 12, 2006 | 07:53 PM
i am adding a gt35 R perrin kit
fmic, meth injection, utec, avcr, iridium spark plugs, pwr radiator , intake, 850 CC injectors, 255 lb fuel pump , catback 3" exhause and about 10 addtion small mods on th e 20th . so please let me know .
Old Mar 13, 2006 | 12:32 PM
gruppe-s's Avatar
Email sent.
Thanks,
Geoff
Old Mar 13, 2006 | 12:36 PM
MARKSTI's Avatar
+1 for the Gruppe-S motors..I've put about 3k miles on mine..VERY VERY GOOD
Old Mar 13, 2006 | 12:47 PM
excel's Avatar
Car Info: 04 STI
Gruppe-S fasho
NorCalDC5
Jul 22, 2009 10:35 AM
bugeyehybrid
Cars For Sale
Nov 14, 2006 09:48 AM
gruppe-s
Engine and Drivetrain
Mar 25, 2006 01:59 PM
UK n00b
Oct 16, 2005 12:18 PM
Top
