What type of water for I/C sprayer?
Old Oct 10, 2004 | 02:04 AM
thsiao's Avatar
Question What type of water for I/C sprayer?
I read somewhere that its suppose to be distilled water... but the saleperson told me just regular water is fine. What do you guys put in the I/C sprayer tank?
Old Oct 10, 2004 | 02:10 AM
soggynoodles's Avatar
I would use distilled water.
Old Oct 10, 2004 | 03:07 AM
gdogg's Avatar
Car Info: 1973 Huevo Ranchero
i use water. theres a guy in HIIC that actually uses a mixture with a certain alcohol(rubbing one i think)
Old Oct 10, 2004 | 10:49 PM
Distilled water is best, depending on how hard your tapwater is. Mineral deposits will clog your sprayers eventually, and possibly foul the pump. Mixing a little rubbing alcohol in helps cool the IC more by evaporating faster, but it's not really necessary.
Old Oct 11, 2004 | 04:56 PM
thsiao's Avatar
This might sound stupid but where can I buy distilled water?
Old Oct 11, 2004 | 06:11 PM
nic3krnnamja83's Avatar
at the market it says distilled on it
Old Oct 11, 2004 | 06:37 PM
Don't forget to use Distilled water when you flush your radiator.
Old Oct 11, 2004 | 07:32 PM
Group B's Avatar
Dahveed aka Robin Hood
also alcohol may not be compatible with the rubber lines?
just a thought...
Old Oct 11, 2004 | 08:21 PM
Keep the mixture low and it's okay.
Old Oct 15, 2004 | 11:53 AM
MVWRX's Avatar
Car Info: '05 Crystal Grey Metallic WRX Sport Wagon
I was browsing this and saw something very wrong. Adding a small amount of any type of alcohol to water RAISES the boiling point. Look up boiling point elevation/ freezing point depression in a chem book. The only way to get a lower boiling point is to use more alcohol than water, and then it will probably have some adverse afects on the I/C spray system. Just stick to distilled water.
Old Oct 17, 2004 | 12:05 PM
Vamz's Avatar
What about the water freezing in the winter?
Old Oct 17, 2004 | 06:23 PM
PyroManiac's Avatar
From: Are you too one of the few still living the past? Well I can change that! With a simple wicket. Yes, my friend, a wicket. PM for details.
Car Info: No car right now....sob.
Fill the tank about halfway in the winter, it won't freeze this way.
Old Oct 25, 2004 | 12:05 PM
technica's Avatar
Car Info: 06" STI OBP
Alot of people use windshield washer fluid in the winter.
Old Oct 25, 2004 | 03:35 PM
DChan's Avatar
Alcohol will help prevent freezing in the winter.
Old Oct 25, 2004 | 03:42 PM
My_Red_Suby's Avatar
Car Info: 2005 Metallic Gray STI
rain water. . . . . .
