What spark plugs to buy?
Old Jan 11, 2004 | 12:57 AM
midnightwrx's Avatar
Car Info: 2004 subaru sti
What kind of spark plugs do you recomend for the STI?
Old Jan 11, 2004 | 01:03 AM
Mach5WRX's Avatar
Angry Dan
Car Info: 05 Evo VIII
The stock ones are just fine.
I'm 80% sure they are "colder range Iridium Spark plugs". I'll try and find the SOA press release I read that said that.
Old Jan 11, 2004 | 01:16 AM
Old Jan 11, 2004 | 05:38 AM
SUB-ZERO's Avatar
I think the stock plugs on an STI and WRX are platinum not irridium. When I installed my STG4+ I swapped out to a set of Irridium 1 step colder.
-SZ
Old Jan 11, 2004 | 06:05 AM
NGK coppers, part #BKR7ES-11s, gapped to .026-.028.
Old Jan 11, 2004 | 12:25 PM
Mach5WRX's Avatar
Angry Dan
I'm not trying to start any thing but this says "Iridium tipped"
http://usdmsti.com/photos/SalesTraining/sti4.jpg <---It's from SOA so there's a 80% chance it's wrong.
Old Jan 11, 2004 | 12:57 PM
ej25lvr's Avatar
Car Info: 04 wrx sti
it says in the owners manual that they are iridium plugs liisted with a part number
Old Jan 11, 2004 | 04:02 PM
Nolimit's Avatar
Where is my beer?
Car Info: NSX, G35
as I've said before, .... using the "-11" plugs is Not the best idea. the "11" stands for the gap that the plugs come in, ... which is .044", or 1.1mm.
As per NGK techs and other sources, you should Never close a gap more than .008 or so. SO with the "11's" you are closing the gap over .015!! About Double the maximum recommended. This can cause irregular spark, causing poor/unreliable performance, fouling, slight misfires, etc.
The NGK copper plug you should use is BKR7E (6097), ... which comes gapped to ~.030~.032".
Don't take my word for it though, you may call the NGK tech line @ 1-877-473-6767.
Cheers
Sean
Old Jan 11, 2004 | 04:08 PM
SUB-ZERO's Avatar
I just checked the stock plugs I took out when I swapped to Irridium. They are NGK Platinum plugs.
Old Jan 11, 2004 | 04:13 PM
ej25lvr's Avatar
i will be majorly pi**** if mine r platnum . they are supposed to be iridium plugs . im gonna go pull one right now just to see.
Old Jan 11, 2004 | 04:19 PM
SUB-ZERO's Avatar
Maybe they are irridium on the STI's. I have a 03 WRX and that came with platinum.
Old Jan 11, 2004 | 04:30 PM
ej25lvr's Avatar
ok just pulled one and mine are iridium ngk: ILFR6B
Old Jan 12, 2004 | 10:22 AM
Nolimit's Avatar
Where is my beer?
Car Info: NSX, G35
Wink
No one ever said the WRX came with irridium, .... just the STi ...... notice how you're in the STi Powerplant -- EJ25T forum .....
Old Jan 12, 2004 | 03:28 PM
ej25lvr's Avatar
lol
Old Jan 12, 2004 | 04:00 PM
SUB-ZERO's Avatar
uhhhhh I feel like a dumbass....sorry I made you take your plugs out. I guess it would help to know in what forum I'm in.
-SZ
