what should i do
Old Aug 23, 2005 | 06:49 AM
antmiller's Avatar
what should i do
i have to rebuild my motor i cant afford the gt35r kit. i orderd a fp red but i cancelled it beacuse it was with an internal wastegate. i thought to my self if i am going to rebuild my motor i am going to go all out but i just cant buy the kit. i have greddy front mount Helix up pipe and down pipe 800cc PE injectors Greddy E0-1 boost controller and UTEC. my question is should i buy the fp red with out an internal wastegate and then put an tail external wastegate or is it a better turbo out there for me i am looking for at least 450 whp
thank you
Old Aug 23, 2005 | 06:59 AM
1reguL8NSTi's Avatar
Car Info: 05 STi
Why are you so caught up on the internal wastegate issue? If you don't have the money to completely rebuild your block anyway then you shouldn't be running so much boost that an external wastegate is that vital. Is it an EJ20 or 25?
Old Aug 23, 2005 | 07:09 AM
antmiller's Avatar
i have an sti, i can fully rebuild my motor thats not the issue i just cant afford the gt35r kit however i still want to run an external wastegate. i have 1,800 to spend on a turbo thats why i was asking what turbo can help me produce 450 whp
Old Aug 23, 2005 | 07:22 AM
Car Info: 05 STi
In all honesty I would get the Green or a 20G. With a rebuilt motor you can get that easy with supporting mods. You could get alot more with a bigger turbo but I'd rather have the quick spool up. I say get the green but if you want a wastegate that bad you could consider a PE1820.
Here are some quick and reputable places to check out some options:
http://www.gruppe-s.com/Subaru/subeng.htm
http://www.rallysportdirect.com/shop...Path/21_26_138
http://www.mpjperformance.com/cgi-lo...y_Code=SENGTUR
Old Aug 23, 2005 | 07:29 AM
antmiller's Avatar
thank you.
Ridoan
Sep 8, 2009 11:40 PM
dr3d1zzl3
Aug 20, 2004 03:19 PM
Edvig
Dec 9, 2002 08:42 PM
obyone
Nov 23, 2002 02:16 PM
Wheels
Nov 22, 2002 04:52 AM
