What motor oils are you using on the STI?
Old Feb 10, 2005 | 11:14 PM
carnut's Avatar
I was curious to know what people are running on their cars as far as oil brands and weight? thanks!
Old Feb 11, 2005 | 09:36 AM
WolfPlayer's Avatar
Mobil 1 Racing. This is not standard Mobil 1. 0W-30.
http://www.bescaredracing.com/sti/oil/m1r/DSC02367.JPG
http://www.bescaredracing.com/sti/oil/m1r/DSC02369.JPG
Old Feb 11, 2005 | 10:40 AM
Disastorpasztor's Avatar
Car Info: Blue 05 STi
Originally Posted by WolfPlayer
Do you use this just for racing or just cruising around on the streets as well??
Old Feb 11, 2005 | 10:21 PM
carnut's Avatar
what does the stock 05 STI oil brand? and is it synthetic?
Old Feb 12, 2005 | 09:11 AM
rexy04STi's Avatar
Car Info: 2004 Java Black Pearl/Gold STi
I'm using Amsoil Series 2000 0W-30 in my STi. Runs like a champ.
Old Feb 12, 2005 | 12:47 PM
DChan's Avatar
I was running Amsoil 10w-30 Turbo formula. But after hearing that a heavier oil doesn't flow through the turbo as well I'm switching back to Mobil1 5w-30.
Old Feb 12, 2005 | 12:55 PM
WolfPlayer's Avatar
Cruising around the streets as well. It is a racing oil that has been designed with plenty of detergents for street use. I'll be sending samples off to Blackstone at 1000 miles, 2000 miles, and 3000 miles.
t
Old Feb 12, 2005 | 04:36 PM
rexy04STi's Avatar
That's why I'm running the 0-30. Been to a couple of track days with and haven't had any problems what so ever. In fact, everytime I've pulled the oil down, it was like it was brand new, not even the slightest burnt.
Old Feb 15, 2005 | 10:54 PM
Group B's Avatar
Dahveed aka Robin Hood
Stock oil is 5W30 dino oil.
I'd recommend using Kendall GT 5W30 until you've got about 7-8k miles, then switch to Redline 10W40 Full Synthetic.
Old Feb 15, 2005 | 10:57 PM
carnut's Avatar
what is dino, never heard of it
Old Feb 16, 2005 | 12:42 AM
downsti's Avatar
Car Info: Big Thanks Jeremy@CrucialRacing and Ed@EQ-Tuning
REDLINE 5w30 makes my car go crazy ... mobile 1 is **** compare to redline
Old Feb 16, 2005 | 12:55 AM
Originally Posted by clsti
i think you guys should use higher oil, Cause i talked to Gushi from Gushi auto and he knows alot about cars and he told me to use at least 5w-50 in my sti because of the turbo.
Your friend Gushi hasn't learned much in 15-20 years. Thinner oil is better at protecting your engine, and any modern synthetic will have no trouble holding up even in the turbo.
Old Feb 16, 2005 | 07:17 AM
Egan's Avatar
I use dino 5w30 in my STi. I'm just about at 11,000 miles. Typically I use the Chevron brand.
I live in Kalifornia, so weather is not an issue in choosing oil weights.
