USDM Sti 2.5 short block kit- who from
Old Dec 3, 2003 | 11:40 PM
BongMan's Avatar
Car Info: '01 RS BRP
I know i-speed was doing a short block into a WRX conversion. If you only need the bottom/middle end you might want talk to them.
i-speedusa.com
hope this helps.
Old Dec 7, 2003 | 09:30 AM
Pi7467mp's Avatar
Car Info: 2000 2.5 RS USDM STI block, SOHC heads GT25 Ball bearing turbo, TMIC, TXS BOV, Tial wastgate, etc...
isrperformance.com
talk to Pam she got me the sti shortblock assembly for 1460 shipped!!!
Old Dec 13, 2003 | 02:56 PM
Pi7467mp's Avatar
Hey man... I Just finished swapping an sti block into my 2.5RS... If you aren't afraid of taking your motor out (which is not a big deal at all) you can do it yourself, and save yourself thousands .... The only problem I ran into was, I forgot to plug in my water temp sensor so I threw a CEL... but I figured it out in a few minutes, and everything works out flawlessley.. My car runs great and sounds awesome.. Let me know if you have any questions I can answer for you.
Old Dec 14, 2003 | 12:55 AM
www.subaruwrxparts.com
$1575 for the short block with gaskets shipped anywhere in the 48 states.
Old Dec 14, 2003 | 07:33 AM
Pi7467mp's Avatar
I know this is a little off subject....kinda... but I just finished swapping out my 2.5rs block yesterday with a USDM sti shortblock... Everything went smmothly except for the blots on the lower right side of my bell housing.. The piping from my turbo was right ion the way so i had to drop my turbo, in order to get to the bolts.. not a big deal but time consuming.. The only problem I ran intop was the parallel fuel rail system... The explanation on I-club, and on ravensblade-impreza was a little off. So I plan on adding better pictures, and better explanations, and more steps so no one is left in the darkk. The other problemI ran into was when I 1st started my car after the install... My fans wouldn't turn off, and my temp guage wasn't working.... 1st thought was water temp sensor, and water temp guage sensor.. sure enough there it was unplugged.. put tat bad boy back in and it ran awesome.. no problems what so ever.. I have a little power steering pump leak, but other than that ( I don't care about power steering, cuz it has nothing to do with going fast) awesome.. it acts like it wants to just take off!!! oh and back to the subject.... 1460 shipped from isrperformance.com ask for pam.
Old Dec 20, 2003 | 12:05 PM
1fastGC's Avatar
Car Info: Evolution VIII
You can order the USDM 2.5 STi shortblock from Mike Shaw Subaru or Gruppe-S.
