USDM EJ25 Firing order
Old Jun 12, 2005 | 02:12 PM
dunnojack's Avatar
Car Info: '07 STI
Question USDM EJ25 Firing order
Does anyone know what is the firing order of the USDM sti motor? is it possible to change that order if a different header is installed?
Old Jun 12, 2005 | 04:37 PM
Wingless Wonder's Avatar
Origami posted by dunnojack
Firing order for both the USDM STi 2.5 and 2.0 is 1-3-2-4.
I don't think it is possible to change the firing order unless a custom crankshaft is ground. The crankshaft throws are ground to position the pistons at top dead center in the firing order. The ECU must also be modified or a standalone system must be used. The factory selected the firing order for optimum balancing and minimum harmonics.
Old Jun 12, 2005 | 04:52 PM
dunnojack's Avatar
Car Info: '07 STI
wow, thanks! also, does anyone know which wire is positive and which wire is negative on the avcs solonoid on the sti motor?
gtfaded
Mar 18, 2007 01:29 AM
EJ_20
Jul 22, 2006 01:23 AM
keirnna
Feb 5, 2005 02:38 AM
flvimpreza
Oct 4, 2004 06:46 PM
dunnojack
May 28, 2004 02:29 AM
