Turboback Problems
Old Aug 30, 2013 | 03:56 PM
TraveX's Avatar
Car Info: 2006 WRX TR
Unhappy Turboback Problems
So i just installed an indivia divorced wastegate dp and nameless catback exhaust on my 06 wrx. install went well except i could not get the o2 sensor out of the stock dp. temporarily filled o2 hole in the new dp with an m18 plug. (need to order new sensor). or if anyone has one... then used my accessport to stage 2 ariz/cal/nev 91. But now the car is running horrible. Car lacks power in lower rpms while trying to accelerate then finally kicks in for a jerky sputtering ride.. WTH?Need help please
Old Aug 30, 2013 | 03:59 PM
MonsterGC's Avatar
Car Info: 2000 2.5rs
well you took out the 02 sensor.....
Old Aug 30, 2013 | 04:14 PM
KillerFoz's Avatar
Car Info: 2005 Forester XT
no o2 sensor car will act the way it is now..
Old Aug 30, 2013 | 04:17 PM
TraveX's Avatar
okay i am going to order a new sensor right now.
i need the downstream right?
this is a denso one im looking at.
Amazon.com: Denso 234-4732 Oxygen Sensor: Automotive Amazon.com: Denso 234-4732 Oxygen Sensor: Automotive
Old Aug 30, 2013 | 04:20 PM
02RS25's Avatar
if you take out a spark plug your car would run like crap...i dont see what the difference is. your car and its ECU is designed to run with an O2 sensor. without it, your car is telling your ECU that its not releasing exhaust gases, or if they are, WAY out of spec and WILL affect your engine performance. throw in that new O2 sensor and take her for a spin. ud be surpirsed at the difference. when i installed my tranny, i knocked off the speedometer sensor and ran without that. just a speedo sensor right? after 4k, t he car would buck and never ever reach WOT. installed new one and she ran perfect. hope info help. GL
Old Aug 31, 2013 | 12:34 AM
TraveX's Avatar
thanks for the info i ordered an 02 sensor will be here on Tuesday hopefully that fixes the problem
Old Sep 20, 2013 | 12:46 AM
TraveX's Avatar
Changed 02 sensor which took the code away although still was not running right. Turns out it was the fuel pump. Put a AEM one now it runs great.
Old Sep 20, 2013 | 04:53 AM
Brfatal's Avatar
Technical Know-It-All
Car Info: '02 WRX + '15 WRX
I dunno, maybe try, er, resetting the ECU?
Old Sep 20, 2013 | 07:38 AM
Heedz's Avatar
Nobody likes the tuna here
AEM fuel pump?
Old Sep 20, 2013 | 11:13 AM
Superusdm's Avatar
Car Info: 2003 WRX
Crazy how everyone on these boards seems to have similar issues happen all at once. My legacy was having a similar problem, idled fine, revved fine in N, but drove like dog **** everytime I gave it more than 10-15% throttle. Super jerky and bucking back and forth in every gear anytime I hit the gas. Swapped to my old oem wrx fuel pump last night and all is well
03'EyeBug
Dec 23, 2010 10:45 AM
WorldONE
Engine and Drivetrain
May 28, 2008 10:51 AM
-WickedRex-
Dec 18, 2006 06:57 PM
grex767
May 27, 2006 10:37 AM
subaru_wrxwagon
Jan 6, 2005 03:35 AM
