titek downpipe reliability??
Old Mar 31, 2009 | 10:47 PM
toofast4u2's Avatar
Car Info: Black 2006 STI
Question titek downpipe reliability??
I want to get a catted titek downpipe, but am not sure how well they are made.. are they reliable? anyone have fitting issues or exhaust leaks because of it? how long have u had ur titek dp?
also what is a CEL Fix Kit? they say it might be required? what is its purpose and do u need to buy it? thanks guys.
Old Apr 1, 2009 | 02:29 PM
toofast4u2's Avatar
bump! ok already got an answer to this, but will a titek dp which is 3 inches fit up to a spt exhaust which is 2.5?
Old Apr 1, 2009 | 02:49 PM
KrAzYkld's Avatar
Car Info: 1998 M3, 2016 WRX
i should fit, but there might be a small leak. nothing really major.
Old Apr 1, 2009 | 03:34 PM
karis119's Avatar
Car Info: 05 STI
I've had my Titek catted dp on about 15k miles and never had a leak or any issue with it whatsoever. Seems to be pretty well made and reliable for the price. As for it fitting with a 2.5 in exhaust I'm not sure since I have mine hooked up to a 3 in exhaust.
Old Apr 2, 2009 | 02:50 PM
kloo413's Avatar
Car Info: '06 GT52'd STi '03 Miata SE
You will have a leak if you try to mate a 3 inch DP to a 2.5 cat-back. Only one side will bolt up flush and you will have a leak on the other. Your exhaust will not sound nice either, as exhaust ambience will be expelled from the leak.
To make it easy on yourself, go get an APS Turboback system. You won't regret it.
ENJOY!
Old Apr 2, 2009 | 07:37 PM
toofast4u2's Avatar
getting a greddy sp2 exhaust so don't have to deal with the 2.5" problem
Old Apr 28, 2009 | 05:13 PM
CHESTON's Avatar
Car Info: AW Pig-STI
i just had GST lop off the 2.5" portion on my Cobb exhaust, weld on a 3" section.
or.......
Kakumei exhaust adapter
Old Apr 28, 2009 | 06:27 PM
dickson's Avatar
Car Info: 2002 WRX Sedan, 2004 Acura TL
I bought my catted Titek DP used at 6k miles. The quality is really good (in terms of welds and flanges). At 6k miles, it still looked semi-new. No rust or discoloration at all. The install fitment was right on.
I've had it for about 8k since install now. When I get under the car and look at it, it still looks pretty good. No leaks that I know of. If you go with the catted DP, you really should consider going with Titek.
With that said...anyone tried to pass smog with UP, catted Titek DP, Stage 2?
Spec Miata
May 4, 2003 11:57 AM
Cyclist1
Apr 22, 2003 04:48 PM
Duane
Feb 25, 2003 01:30 PM
Scooby1
Jan 6, 2003 03:26 PM
