Throwing CEL's after going cat-less
Old Apr 29, 2009 | 11:28 AM
06WRXtacy's Avatar
Car Info: '06 SGM WRX / 18G (300/291) RIP, '05 TB Evo VIII
I recently just made the switch from high-flow, to catless downpipe. I had been tuned with the cat so I turned down the MBC a little to try to compensate. I was peaking at 19.5psi before. Since the install, I have thrown a CEL the last 3 nights. Code is P2044, Turbo Boost Wastegate Solenoid Range/Performance. Last night I was peaking at 18.1 yet still threw a code. My boost gauge isn't installed so I was using my accessport to read boost. Temps were in the 40's so that may have had something to do with the spike. I'm not going to get re-tuned for this since I have other mods coming up that would require me to do so. I'm going to turn down the MBC even more but is there something else I should do? Hickups at 6k are scary as sheet. Any help would be appreciated. Thanks.
Mods:
18G, perrin tmic & inlet hose, spt intake, titek d/p, greddy evo2, hallman mbc, cobb ap v1
Old Apr 29, 2009 | 12:18 PM
pull the MBC off? see if it spikes that high and dont boost so hard until you get a tune?
Old Apr 29, 2009 | 07:50 PM
Woodward's Avatar
banned
Car Info: 2006 Subaru Impreza WRX TR
I had the same problem a couple years back. I used Cobb's ST to log/tune/log/tune my WGDCs. I think Cobb has a free program now to tune it yourself, but I'm not too sure.
I'm guessing this is happening in 4th and 5th gears?
Old May 1, 2009 | 03:34 PM
06WRXtacy's Avatar
Happened in 3rd gear right around 6k, I'd be going way to fast to find out in 4th and 5th. Turned mbc down a little more and that seems to work for now. Don't really want to pull the mbc and run wastegate boost since I probably won't get tuned for a while. Thanks for the suggestions guys.
Old May 1, 2009 | 09:19 PM
C89ZX7R's Avatar
banned
Car Info: 2004 STi
Stop getting into the throttle right after you reset the ecu.
Old May 2, 2009 | 08:11 AM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
If you don't recalibrate the ECU properly and soon, you will most likely destroy your engine.
Old May 3, 2009 | 04:59 PM
NorCalSubie07's Avatar
Car Info: 07 STi Limited #359 UGM
U really need a retune asap before u destroy ur motor. Hit up ed at EQ tuning or Paul at dbtune, they will fix it for u in a jiffy. Cost a pretty penny, but better than new motor or other parts.
Old May 3, 2009 | 05:01 PM
04caliwrx's Avatar
you were tuned with a cat the first time, you are flowing more air and going to running different without a cat on your car. You should really thing about a retune.
Old May 4, 2009 | 01:01 PM
06WRXtacy's Avatar
Ed tuned the car originally. I understand that I'm going to boost higher without the cat and that if I turn the mbc down too far I might be hitting different load cells on my map. I just figured since I was tuned conservatively prior with a high flow cat, which titek claims only a 3-5hp loss, I should be ok driving around for a while. I obviously don't want a blown motor but I will be getting tgv deletes and grimmspeed pnp'd exhaust mani soon which would require a whole new tune again.
Old May 4, 2009 | 10:35 PM
C89ZX7R's Avatar
banned
Car Info: 2004 STi
find someone with the exact same mods and copy their map been running on someone elses map for 30,000 miles.
Old May 4, 2009 | 11:47 PM
Woodward's Avatar
banned
Just take it easy.. ie no WOT till you're properly tuned.
I've got TGV deletes for ya too!
Old May 5, 2009 | 07:35 AM
VRT Gump's Avatar
without a proper tune, expect to go boom!!
please tune the car so you can enjoy it how it is supposed to be, you will tell a world of difference.
Old May 20, 2009 | 08:34 PM
knock's Avatar
Car Info: bici putas
yeah and furthermore the lack of a cat will cause the bank2 oxygen sensor (post cat) to read out of spec and throw a code.
Old May 22, 2009 | 07:16 AM
ZOMG.STi's Avatar
Car Info: 2005 Subaru STi
Just like what everyone else said, dont go tooling around. HOWEVER, if you plan on doing these mods soon dont waste money in a tune right now. Better yet, since you're coming back, ask your tuner for a limp map until you get the parts.
i<3dirt
Oct 20, 2014 10:26 AM
Steve278
Nov 5, 2013 04:18 PM
blackbullet03
Wanted
Aug 2, 2009 04:40 PM
ezombie
Apr 26, 2006 07:37 PM
mattsn0w
Feb 28, 2005 01:48 PM
