Stock injectors on an 18g?
Old Feb 14, 2007 | 06:15 PM
1sicwrx's Avatar
Hey guys,
I have done some searching and have achieved nothing but mixed opinions. I have an 04 STi and just purchased an FP 18g with an upgraded turbine housing(7cm to 8cm). I have some other power mods like, header, APS turbo inlet pipe, Cobb uppipe, TBE, Cobb intake, 255lph fuel pump and Accessport for engine management. I have found multiple instances of people running the 20g with stock STi injectors and still have a little bit of head room for saftey precautions while getting pretty good numbers. I understand that tuning is going to be a HUGE factor in how the stock injectors are going to perform. I was just wondering if someone had a similar set up and all of your guy's input would be greatly appreciated.
Old Feb 15, 2007 | 06:57 PM
pj21086's Avatar
I've heard of people doing it without aftermarket injectors but usually theres something to it. they're usually running meth or have a stock catback, etc. i would definately upgrade them. the injectors on my 05 sti are maxed out on the stock turbo at 16psi
Old Feb 25, 2007 | 06:41 PM
teh cdogg's Avatar
Car Info: 02 WRX
I maxed out sti pinks in no time with a td05-18g. Minimum the say for an 18g is like 640cc. I went with some modified stockers from andrewtech flow tested at 857cc and they work perfectly,
ghettojet
Apr 5, 2011 06:34 PM
boostfed
Jul 5, 2009 10:09 PM
WRXdavid
Jan 30, 2009 07:55 AM
starletmunchkin
Dec 23, 2006 09:29 PM
