STi up pipe
Old Nov 5, 2003 | 01:07 PM
SuboobaruWRSEX's Avatar
Car Info: Viper ACR & H1
STi up pipe
Does the STi up pipe have a sensor hole in it like the WRX does? I know it dosnt have a cat, but I am looking for an aftermarket up pipe and need to know if the aftermarket pipe needs a hole or not.
Thanks,
Nick
Old Nov 7, 2003 | 12:26 AM
You can use the STi uppipe, just get a 2.2k ohm resistor to stop the CEL.
Old Nov 7, 2003 | 06:06 PM
This thread is asking if an STi uppipe can be used on a WRX. Since the WRX ecu is expecting an EGT signal from the uppipe and the STi has no provisions for one, you would need the resistor in your WRX wiring harness where the EGT sensor was plugged in if you wish to avoid the CEL.
Old Nov 7, 2003 | 08:52 PM
If you have an STi, you have little to gain by changing the uppipe. The turboback makes more power, and better bang-for-the-buck.
Old Nov 12, 2003 | 10:12 PM
No, it wasnt aimed for a non STi. I have and 03 WRX and am lookin to buy an STi. Proably gonna get a Gruppe-S header with a helix up pipe (STi). My origional idea was to take the Gruppe-S up pipe off of my 03 and put it on the STi and stick the stock STi one on the 03 before I sold it. But since that wont work. Does anyone made an up pipe without a hole in it? Aftermarket proably weighs less and is better flow than stock.
Nick
Old Nov 13, 2003 | 01:31 AM
Sorry, first post seemed as if you wanted an STi uppipe for an EJ20.
As for weight, I doubt a quality uppipe is significantly lighter than the OE piece. As for flow, you *might* be able to improve that, but I dunno if you would get your money's worth out of it, or enough power to justify the trouble of changing it. Even by removing the cat in the WRX uppipe, the gains are only about 10 hp. With no cat to remove, I doubt there would be a significant difference. I would not replace the uppipe unless I was also going to a larger turbo and was concerned about spool up.
Old Nov 13, 2003 | 11:37 AM
Gruppe-S header is $399 with a helix up pipe for $499 shipped. Not a bad deal. If I didnt like it could most likely sell it for what I paid.
Nick
Old Nov 18, 2003 | 06:26 PM
Hummer's Avatar
Car Info: STi Stage 1
I have the Gruppe S type II header and I like it. I left the oem uppie in place. It was not worth the hassle and cost for minimal gains{unless you are swapping out the turbo}.
Old Nov 18, 2003 | 08:07 PM
Thanks. Did you notice any power increase?
Nick
vsick
May 16, 2011 02:26 PM
dek0i9
Apr 21, 2009 03:17 AM
fliped wrx
SoCal Classifieds
Jun 8, 2007 10:52 PM
gdbimpreza
Mar 3, 2005 12:12 PM
gdbimpreza
Jan 20, 2005 05:25 PM
