STI Turbo/TMIC
Old Sep 8, 2005 | 09:02 PM
depdivr's Avatar
Car Info: 2005 Black WRX STI
STI Turbo/TMIC
Hi all,
I just bought my wife an 05 Outback Legacy XT (Turbo Outback, 250 hp etc, 2.5L). I have my old stock STI USDM turbo and TMIC sitting on a shelf from my FP Red/Perrin FMIC swap. I was curious if anyone sees an issue with swapping the USDM Outback Turbo and TMIC with the USDM STI Turbo/TMIC. Both are 05 models.
I would get and Ecu-Tek re-flash for the tuning. I think that I could probably get up to 230 whp from what I assume to be about 190. I don't think at this level I will have to upgrade injectors. Everything else will remain stock.
I would love to hear what you all think.
Old Sep 10, 2005 | 03:56 AM
4080wrx's Avatar
if i'm not mistaken you still need injectors and a fuel pump a vf39 is similiar to a vf34...anyone else care to provide feedback
oh wait i just realized you said you its an outback legacy ok disregard not sure about that one
Old Sep 10, 2005 | 08:37 AM
depdivr's Avatar
nKoan completly helped me out with this
This was from nKoan:
"The STi intake manifold throttle body (and intercooler connection point) is on the top of the manifold, in the center. The Legacy GT manifold has the throttle body off to the right.
Since both throttle bodies are drive by wire, I'm pretty sure that the STi one will work with the LGT.
Check out this thread for more info:
http://www.legacygt.com/forums/showthread.php?t=6528 "
I know that the above thread doesn't have anything specific to do with the STI powerplant but it is a very good description and photojournal of the instalation of a STI turbo, TMIC and Intake Manifold on a Legacy GT (very similar to a Outbact XT).
Thanks again to nKoan!
Old Sep 10, 2005 | 10:24 PM
Krinkov's Avatar
Just to add, all the 2.5 turbos should use the same 480cc injectors and the same fuel pump, so once tuned you should be good to go there too
Old Sep 29, 2005 | 06:55 PM
firedawgs's Avatar
Car Info: 2005 Legacy GT
+1
You will need at least 3 things: VF39 turbo, intercooler, and intake manifold.
The use of a TGV housing will allow direct bolt on of the manifold. The injectors are the same and the fuel pump is fine.
I am in the same boat as you. I am trying to make my 05 LGT a STi. All I have right now is the TGV housing. I am in the market for the turbo, TMIC, and the manifold.
Old Sep 29, 2005 | 10:43 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
Get the STi turbo, I/C, ecu, & manifold...instant Legacy STi.
Well, you'd have to add Brembos, exhaust, 6spd.....
doc_randy
Jun 6, 2010 04:23 PM
JDMGC8
May 29, 2009 08:07 PM
blinguskahn
Oct 8, 2005 10:47 AM
iNfEk
Feb 16, 2004 01:16 PM
K2Skier
Mar 29, 2003 07:00 AM
Top
