SPT intake question
Old Jul 6, 2008 | 12:32 PM
AWDnutjob's Avatar
Car Info: 2004 PSM STi
SPT intake question
any with one of these, what is the inner diamter? how close to the stock piping is it? i need to buy a carb legal intake...... but i think this will be too small for my turbo's needs......
thanks in advance...
Old Jul 6, 2008 | 12:37 PM
Irish_car_B0mb's Avatar
I have SPT. it works fine
i really dont wanna go out and measure but from what i remember it is just a tiny bit bigger than the stock. the hose coupler that connects the 2 is just a tiny bit bigger and the intake side than the other.
Old Jul 6, 2008 | 06:04 PM
AWDnutjob's Avatar
well i was asking size, because i usually run a larger turbo ( 20g ) and i need a 3" maf housing.... i think the spt is too small....
Old Jul 6, 2008 | 06:33 PM
i will go measure it in a bit and i will get back to you
Old Jul 6, 2008 | 06:50 PM
yeah i just measured it and it was 2 3/8 I.D.
Old Jul 6, 2008 | 06:56 PM
WRX409's Avatar
Car Info: 04 WRX
I hope you have a turbo heat sheild like the SPT turbo heat
sheild or your CAI will be sucking in hot air instead of cold.
Have you looked at the Cobb Tuning intakes?
Old Jul 6, 2008 | 07:06 PM
i got the heatr shield you can see in the pic. also after install and batt disconnect i had it ran and a/f is all good.
Old Jul 6, 2008 | 07:19 PM
WRX409's Avatar
Car Info: 04 WRX
Can you remember off the top of your head what the
A/F ratio was?
Did you actually notest a difference in performance?
Better throttle response or anything?
Old Jul 6, 2008 | 07:40 PM
I think it was 14.5-14.6:1 somewhere in there and as far as performance i did notice quicker spool up, well a little less spool lag anyway.
there is alot of wooshing and swooshing though. saved money on a BOV. sometimes you can hear outside the car but the sound is mostly for my enjoyment. it was distracting at first but nowadays i dont even hear it unless someone points it out.
i did combo it with a SPT exhaust and i noticed smoother spool up easier shifting and smoother accel. people will go one way or the other one short ram. the have a thread called THE GREAT INTAKE DEBATE or something . From personally having it i like it and i recommend to anyone. Especially if you worried about staying on dealership warranty.
and if that didnt answer your question Just for kicks after driving it for a bit with the SPT parts i thorugh the stock intake on with and without the stock exhaust and noticed more lag and less fluid accel with the stockers stuff on. i hope this helps
Old Jul 6, 2008 | 07:57 PM
WRX409's Avatar
Car Info: 04 WRX
That definitely answers my question thanks Irish.
The SPT intake is the only intake I have seen that holds a
decent A/F ratio without tuning.
I have a warranty with Subaru and I will considering getting one
I appreciate your insight.
Old Jul 31, 2008 | 04:02 PM
scoo*B's Avatar
Car Info: 07 specB
are u sure about that?! thats crazy lean bro...
Old Jul 31, 2008 | 05:53 PM
jinorazi's Avatar
Car Info: 05 cgm imp
from my research, only 3 intakes are cool with the car(sti)
aem
spt
and k&n intake sri which is what i got and my car is running fine. just recently dyno'ed it 275awhp @ gst's mustang dyno and mike said my car is running fine and consistant.
got it for 200 w/ shipping on ebay.
Old Jul 31, 2008 | 08:20 PM
04caliwrx's Avatar
I had this on my car when I was at 349whp and it did fine with my 18g, this is a great rmi and will work great with you car
jamoc
May 28, 2010 01:03 PM
TURBEAU
May 22, 2010 11:42 AM
wrxchase
Mar 22, 2009 10:04 PM
wagonator29
Dec 8, 2007 07:20 PM
