Smoke coming from turbo? Help
Old Aug 25, 2012 | 09:37 PM
CcaniaSTI's Avatar
Car Info: Flared laguna seca GD
When i got home from work i notice smoke coming out of thr turbo it was to dark for me to tell what colo smoke it was. Anybody have any suggests what could it be blown turbo?
Old Aug 25, 2012 | 10:31 PM
Brfatal's Avatar
Technical Know-It-All
Car Info: '02 WRX + '15 WRX
Look tomorrow?
Old Aug 25, 2012 | 10:35 PM
CcaniaSTI's Avatar
Yah ill check it hopefully its not a blown turbo
Old Aug 26, 2012 | 10:34 AM
92xsaabaru's Avatar
Car Info: 05 saabaru
it could possibly be the banjo bolt of the turbo letting oil out which is then burning from the heat of the turbo causing it to smoke, just a suggestion to look at
Old Aug 26, 2012 | 11:04 AM
CcaniaSTI's Avatar
Ill take a look ifmits the banjo bolt. i checked this morning i saw that my coolant and oil level went down?
Old Dec 19, 2012 | 05:25 AM
Frank Lacy's Avatar
^^^ check that. and i wouldnt think the turbo would be smoking. thats odd. even with a blown turbo it doesnt typically smoke from the turbo. are you smoking out the exhaust? typically its the seal around the turbine shaft that starts leaking oil and then it gets evaquated through the exhaust. if your actuall turbo is smoking you probably just got something on it or one of the clamps could possible be loose. check the turbo exhaust manifold. maybe a bad gasket. or could be the v-band clamp although i doubt it.
Old Dec 20, 2012 | 09:46 PM
1JavaBlk_in_Sac's Avatar
Car Info: $2000 hawkeye
it's not a turbo
Most likely your valve cover is leaking and dripping on hot uppipe causing smoking
obdrummer
May 21, 2014 06:33 PM
Chrisnonstop
Jul 17, 2008 08:48 AM
bluesubeguy
Dec 31, 2003 07:24 AM
KenshinPlates
Jul 11, 2003 01:11 PM
yamaha1995
Jun 10, 2003 04:56 PM
