Should I AP, or go with TBE
Old Sep 2, 2006 | 05:31 PM
mperalta's Avatar
Car Info: 2005 sti
Question Should I AP, or go with TBE
aaa
Old Sep 2, 2006 | 06:10 PM
subie OCD's Avatar
Car Info: 04 STi
Accessport. It will smooth out the torque curve while adding power. Plus, when you do end up getting the dp, you can reflash the map. Also, the AP reads CEL codes which is a big plus.
My 2 cents. Im sure the next post will say, "Downpipe"
Old Sep 2, 2006 | 06:52 PM
VRT Gump's Avatar
AP will give you more right now and if you run just a downpipe you will have a chance at having turbo creep. My first mod was an AP and it helped a lot.
Old Sep 2, 2006 | 10:03 PM
Carnitas's Avatar
Car Info: 06 WRX
go with the ap
Old Sep 3, 2006 | 12:09 AM
turbo_4_life's Avatar
Car Info: 04 wrx
definately worth your while to go AP
Old Sep 3, 2006 | 08:31 AM
mperalta's Avatar
Car Info: 2005 sti
How about the access port with only the downpipe, running stock catback?Thanks for the replies so far.
Old Sep 3, 2006 | 08:40 AM
Jakes02's Avatar
Car Info: 2002 WRX
AP with an aftermarket downpipe/stock cat-back would be fine. You may want to do the DP and the cat-back all at once just to save your self some time but if you don't have the money, do what you can. My Invidia DP didn't come with the turbo/DP gasket so you'll want to check and see if the DP you get has a gasket or go get one from Subaru.
Old Sep 3, 2006 | 08:54 AM
NorCalBugEye's Avatar
Car Info: 413whp/461wtq
i'd definately go with the AP first if you had to choose. a tbe would cause boost creep, and while the only real way to get rid of it is to port the wastegate, the AP does do a good job of masking it.
Old Sep 3, 2006 | 09:28 AM
VRT MBasile's Avatar
as seems to be 100% of the concensus (sp? I was trying to sound smart) go with the AP first for all the reasons already cited
(I are teh sm4rt)
Old Sep 3, 2006 | 10:31 AM
mperalta's Avatar
Car Info: 2005 sti
Thanks guys. This site is great!
Old Sep 3, 2006 | 01:10 PM
pj21086's Avatar
If you want to keep your motor and ur tbe i'd go with the accessport first or else you can say bye bye to your motor . You need engine management if you want to have a tbe.
Old Sep 4, 2006 | 03:25 AM
Jakes02's Avatar
Car Info: 2002 WRX
Talking
Originally Posted by MBasile
(I aren't sm4rt)
fixed
LOL, try as you may, you are not fooling those who look upon your words.
oh, fyi. it was spelled correctly
Old Sep 4, 2006 | 08:31 AM
haha, thanks asshat
Old Sep 4, 2006 | 07:07 PM
WRX409's Avatar
Car Info: 04 WRX
The Cobb accessport is a excellent bang for the buck I would go with that.
Old Sep 4, 2006 | 10:05 PM
mperalta's Avatar
Car Info: 2005 sti
Ap
I think I will consider it, not sure about the dough though.
