In search of new motor, any Ideas??
Old Oct 30, 2009 | 12:20 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
^ i don't know about that one... he is rocking a very set up sti with a gt30r lol. But if you want a killer car you can buy my full built 2.5 wrx for 20k so I can get my new zo6
With a DBTuned built engine.
Old Oct 30, 2009 | 01:12 PM
04caliwrx's Avatar
I know this Paul lol.
Old Nov 7, 2009 | 10:56 PM
l ANTHONY FTW l's Avatar
Car Info: 2004 subaru impreza wrx STi
lol just pick a bay area shop.... they al build great motors.... as for me a GST built one for me been running over a year now and havent had any problems.
Old Nov 8, 2009 | 08:12 PM
Shayhan27's Avatar
Car Info: LUMPY CGM 05 WRX
Im rockin a GST Installed motor and have over 10k on it no problems. Plus it was affordable.
Old Nov 18, 2009 | 06:17 PM
colton.'s Avatar
Car Info: 03 SRP WRX
i was in the same position..i needed a motor so i took it to Paul, he took care of everytihing and now my car runs like a champ. Im not trying to turn this into a vendor review thread but Paul is the man!
Old Nov 23, 2009 | 08:15 PM
boxerfxt's Avatar
Car Info: 2005 forester
does paul build his own motors?
Old Nov 24, 2009 | 08:29 AM
iClub Silver Vendor
I sub the work out to my three minor children; small hands can get into the nooks & crannies of the boxer engine.
Old Dec 20, 2009 | 10:58 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
We've been building quality engines since we opened the shop in Fairfield. All of our motors have been running without any issues ranging from 280whp - 500whp. We are in the process of setting up an assembly clean room that should be ready in about a week.
We also have a great new option for the 2.0/2.5 hybrid folks. As most people know, when you run a 2.5l shortblock with 2.0l heads, the compression ratio is too high to safely run on pump gas. The common approach to resolve this is to use a thicker head gasket to try to bring the compression ratio down. While this can bring the overall compression ratio down, it is by no means ideal. The resulting combustion chamber shape remains inefficient since you're leaving the 2.0l chamber in the heads untouched. You are in essence shrinking the quench area and introducing several edges to the combustion chamber that can build up heat and cause knock. This of course makes the engine less efficient than a full EJ257 with heads.
Instead of using a thicker head gasket, we decided to try something a bit different. We worked closely with our machine shop to actually map out the combustion chamber of the 2.5l STI head and create a CNC program to replicate the exact same chamber every time. Using this program, we then set up the 2.0l head castings in the CNC and machine out an exact copy of the 2.5l combustion chamber in each 2.0l head. We are then able to use a quality OEM head gasket and maintain the exact compression ratio of a full STI engine. This greatly improves the quench area and overall efficiency of the engine because you now have the exact same combustion chamber as a full EJ257.
-- Ed
porTURBOer
Dec 5, 2007 02:52 PM
scooby_sti
Dec 31, 2006 05:00 PM
Monyg85
Jul 31, 2006 10:17 AM
knate1967
Feb 3, 2006 05:42 PM
bobski
Nov 21, 2002 06:45 PM
Top
