Running low boost.. ideas?
Old Nov 25, 2006 | 07:54 PM
Manoxide069's Avatar
Car Info: 06 Black STi
Alright.. My Sti is cobb stage two with damn near every bolt on less of a turbo upgrade. Today I got a muffler shop to rig up a 3" pipe that I could bolt on to my muffler section for racing so I could just run open pipe. Well I put that on and drove down to the gas station and filled it up with 100 oct and switched my map to Stage 2 93 oct with a real time map of STU 100. Went down the freeway and it felt like crap so I plugged my accessport in and I am only peaking out at 15 pounds of boost. I went back to the house and unplugged the battery and let it sit for a bit then plugged it back in and ran the STU 100 map again and still only 15 pounds.... Anybody got any ideas?
Old Nov 26, 2006 | 09:09 AM
Egan's Avatar
What boost are you seeing on your normal map? That would tell you if it was a mechanical problem or just a bad STU100 map.
Old Nov 27, 2006 | 07:57 PM
I was hitting in between 18 and 19.. Somewhere in that general area.. But yesterday I took off the pipe and put my muffler back on, then I tuned it back to stock, disconnected the battery for a while then tuned it back to stage 2 93oct then did the STU 100 real time map and its running like a savage now.
djwonder925
Apr 21, 2013 12:05 AM
gruppe-s
Engine and Drivetrain
Oct 18, 2006 07:46 PM
flvimpreza
Oct 6, 2005 12:52 PM
shazaam
May 7, 2004 02:40 PM
wonton2049
May 4, 2003 06:29 AM
