The right way to go with an exhaust?
Old Aug 28, 2006 | 01:19 AM
Carnitas's Avatar
Car Info: 06 WRX
well im saving up for my exhaust right now, and well i have it down to where i want to go with the turbo xs turbo back exhaust. i have heard things about mixing up brands together isnt good, like geting a helix dp and then an hks catback wouldnt be as good as the same brand dp and catback. is any of that true at all? i was starting to look at the invidia g200 catback and then going with one of their downpipes, or possibly the espelir catback and some type of downpipe. any insight into this would be greatly appreciated. and if this has already been covered, then i apologize.
Old Aug 28, 2006 | 06:42 AM
dubwrx's Avatar
Car Info: 2004 STi
if they mate together, all is good. i have run a couple of different mixes and worked fine...
all in how much money you want to spend.
Old Aug 28, 2006 | 07:39 PM
Carnitas's Avatar
Car Info: 06 WRX
well i found a espelir gt500 for 360 bucks, so i was thinking of picking that up, and then going with a downpipe later on. how are you able to find out if they mate together? trial and error?
Old Aug 28, 2006 | 08:37 PM
DTO808's Avatar
Car Info: 06 WRX TR
i wanted to buy the turboxs tbe as well and i havent looked around much but i could only find it new for 1k and there are many just as good a lot cheaper so im not too sure which one to get now
Old Aug 28, 2006 | 09:04 PM
Jakes02's Avatar
Car Info: 2002 WRX
It should line up, their is a sliding bracket at the back of the downpipe that gives you a little play.
Old Aug 28, 2006 | 09:06 PM
Jakes02's Avatar
Car Info: 2002 WRX
IMO, what it boils down too is what style you want, how loud and how much you can afford.
I wanted single tip,loud and semi-affordable so I went with Invidia and I am very happy with it.
Old Aug 28, 2006 | 10:43 PM
Carnitas's Avatar
Car Info: 06 WRX
well im lookin for single tip, more of a deep loud sound and again pretty affordable. what dp are you running, if any?
Old Aug 29, 2006 | 01:28 PM
DTO808's Avatar
Car Info: 06 WRX TR
Price isnt a big thing to me if it is only a couple hundred apart from each other so basically i just want a stainless steel exhaust that makes a semi-loud sound.
Old Aug 29, 2006 | 01:53 PM
Carnitas's Avatar
Car Info: 06 WRX
well i found myself a used espelir jgt500 going for 360, i can maybe take it down to 320 or so. it was on an 06 so it hasnt been used very much. i was looking at how much new ones would be, and they only have the jgt500r and those are about 550 bucks. you think its worth it to save the 200 bucks and get a used one? i would check it out before i bought it of course, but if it looks good and everything, is it better to save that extra cash for a downpipe?
Old Aug 29, 2006 | 02:01 PM
stamps's Avatar
Car Info: 05 aspin sti
absolutly, if that is the cbe you want get it used (in good condition). Check to see if it is a full 2.5, 3, 3.5 exhaust. some of the 3" taper to 2.5 where they bolt to the down pipe, if you plan on putting a 3" dp later you'll probly want a full 3" cbe now. (I put my dp on 1 day after buying my sti, cbe will be here tomorrow, borla xr-1
Old Aug 30, 2006 | 01:24 AM
Carnitas's Avatar
Car Info: 06 WRX
well now i was able to find a brand new one for 450, so im gonna get the new one, just cause i trust a new one more. and its 80mm and tapers into 100mm so its actually 3.14 inches and then goes up to 4 inch opening.
EpsilonK
Jan 21, 2006 03:45 PM
fish4poi
Sep 27, 2003 10:46 PM
UU R X
Aug 18, 2003 07:56 PM
andyC
Mar 31, 2003 09:18 PM
fatcatturbo
Jan 6, 2003 08:47 AM
