planning to do a 20g set up
Car Info: 06 WRX, 04 FXT, 02 Forester L, 95 JDM LGT
well im planning on a 20g set up for my wrx. i got a 2006.
im trying to decide for the best TMIC. should i go with a helix of perrin TMIC? also was currious if an STi TMIC would work with this setup.
im going to be running the walbro fuel pump and stock injector. yeah, stock injectors. ill upgrade later but for now the the 565 top feed blue wrx injectors should be fine.
anything im missing? i have spt intake, helix dp with high flow cat and ecs, borola hush catback.
im also interested in getting some type of intercooler spray system, not sure yet cause of cost. ill probally just get a hood scoop air splitter instead.
anyone have any advice as to what else i should add incase im missing something
thanks
thanks
I have seen people run the 20g on a STi top mount but it's obviouly a little restrictive. If you go that route you may want to look into methane injection but you might as well get a after market top mount since it will be only like $200 more. APS top mounts are the shiznit by the way and are $695. You really need to upgrade your injectors if you want that 20g to do what it's intended to do, you should get Power Enterprise 850cc injectors too.
yeah i plan on getting the upgraded injectors in a couple of months and just have a moderate tune for now. ill look into that APS TMIC.
I have no idea what 1sic is talking about. Methane injection WTF??? APS the shiznit??? STi TMIC too restrictive where the hell do you get this crap?
Here's the deal, Then STI TMIC will work, as with any TMIC you are going to get heat soak. For a real upgrade with a 20g turbo consider a FMIC. Injectors are a must, you are almost doubling the cmf by switching to a 20g. I have a 20g with a TMIC. I had the JDM STi TMIC, I sold it and installed an SSautochrome(ebay) TMIC. See an intercooler isn't a complex component. To say one core is better than another is hog wash.
well i talked to mike at GST and he said that on pump gas for a 2006 WRX i can run the 20g on stock injectors and i sould get either a spearco or perrin TMIC. he said i'd probally see 290-300 awhp.
this guy has no clue what he's talking about...
Originally Posted by 1sicwrx
I've also talked with a couple guys from Gruppe-S and they suggested that I get methane injection if I was to run my stock STi top mount with a 20g turbo, becuase, as you know I am considering upgrading my turbo on my STi as well. Sorry if I mislead anyone.
Anyways im pretty sure you meant methanol/water injection.
.Go with what mike said rallied out wrx.
