Oil Feed and Avcs Line!!
Old Apr 4, 2012 | 03:12 PM
SubieSTI209's Avatar
Car Info: 2005 WRX STI
Ok just my luck i was heading out to enjoy my friday night when i started to see smoke coming from the Scoop.. Well after I drove to a friends shop I popped the hood and after some long searching i notice the oil feed line has a tiny crack and Avcs line also has a small crack... well i called up Subaru for the replacement parts, But i dont really feel like taking off the Intake Manifold just to replace a line.. Soo i was searching online and found P&L Lines https://www.iagperformance.com/shopp...rod=PL-SubAVCS just wanted to know if anyone is using these line? and is the install easy or Im i going to have a long day?? Any Info Helps thanks
Old Apr 8, 2012 | 12:00 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
I've use these lines in my old STI. Fitment is a little tricky but not bad. I believe we had to get the orientation of the fittings just right to prevent them from leaking. Just make sure to double check that everything is sealed right and not leaking.
-- Ed
nation
Mar 8, 2009 11:02 AM
2.5 DOHC
Jan 17, 2005 06:00 PM
ethanrulz
Apr 4, 2003 03:31 AM
international B
Mar 16, 2003 11:59 AM
JoeT
Nov 26, 2002 04:46 PM
Top
