oil cooler
Old Oct 20, 2005 | 09:05 PM
05aspenrex's Avatar
Question oil cooler
Do you have to relocate the oil filter to add one? I have a spacer with 2 3/8"
inlet and outlets. My question is do I have to relocate the oil filter to use it? ie. above or below the cooler itself? Thanks in advance.
Dustin
Old Oct 23, 2005 | 12:58 PM
05aspenrex's Avatar
My question is does it matter if the oil cooler itself is above or below the oil filter?
Old Oct 25, 2005 | 09:30 PM
RallySportDirect's Avatar
Former Sponsor
Car Info: GC,GF,GD,GR,GH
No, the Process west oil coolers for example, place a adaptor between the oil filter and the engine block, then it had two lines that run up to the cooling core, one is the supply for the cooler, then the other is the return. The new process west oil coolers even have gauge ports on the sandwich adaptor, so you can hook up your oil temp and or pressure gauge.
It does not matter where you put the core, the pressure of the system will push the oil anywhere you place the core.
Let us know if you have any more questions.
Nick
RallySport Direct Sales Team
Old Oct 26, 2005 | 09:41 AM
v8killer2pt5's Avatar
Car Info: 2004 sti wrb
Those kits are beautiful too bad they are pricey, B&M has a few but not with the oem fitment like that.
Old Oct 26, 2005 | 09:29 PM
05aspenrex's Avatar
Is there anyway to purchase just the cooler posted above without the rest of the kit seeing as I already have an adapter, and stainless hoses? Thanks for the reply.
Dustin
Old Oct 26, 2005 | 11:53 PM
midknight's Avatar
Look around on ebay, there are always cores floating around. You might actual find one that you like better...
Old Oct 27, 2005 | 12:59 PM
Former Sponsor
05aspenrex- Im sorry the kits only come as a whole. Best bet would be to just buy a core. You can get them from any big Race store. Summit jegs ect..
Rick
Old Oct 27, 2005 | 01:05 PM
j*bishop's Avatar
Car Info: ass, grass or cash. no one rides for free
rick,
any way you can take and underbody shot?
TIA
Old Oct 27, 2005 | 01:55 PM
Former Sponsor
im sorry that is all the pictures I have for that kit. I could probably find you a pic of another kit(similar) Are you just wondering about the adapter block?
Rick
Old Oct 27, 2005 | 01:57 PM
j*bishop's Avatar
yes. thanks
Old Oct 27, 2005 | 02:11 PM
Egan's Avatar
Nick
Rick, doesn't the core have to be higher than the filter in order for the oil to drain back properly? I would be worried about oil staying in the core during an oil change and then putting in too much oil when I fill back up.
BTW, I have the process west setup and it works great. It was a perfect fit and rather simple installation.
Old Oct 27, 2005 | 02:17 PM
j*bishop's Avatar
mind takin some pics for me??
Old Oct 27, 2005 | 02:59 PM
Egan's Avatar
I have some pics in the computer at home and I'll dig them up.
This pic will have to do for now. I bought the black version for stealth. It is mounted behind the STi badge.
Old Oct 27, 2005 | 03:06 PM
j*bishop's Avatar
no prob thx!
Old Dec 15, 2005 | 11:12 PM
j*bishop's Avatar
bump for pix!
