oil (consumption) problem?
Ok, I went to the dealer last week to get my STi serviced and checked out. They told me that the penzoil oil filter was leaking. Like I said in my previous post, there is no oil on the floor in my garage. And I looked under the car, and never saw any visible leaks. So now they have me taking the car in every few hundred miles, and they check the oil. It's been around 850 miles since my service. And so far, it has been fine. The level has not gone down noticeably like before. They didn't use synthetic. I don't know what they did, but it seems normal again.
I kinda feel like the guy who has a "problem" with his car or cell phone, etc and brings it to the dealer/store to have it fixed. Once you get there, the noise/malfunction or whatever it was, for some reason, stops and doesn't happen while you're there. Then you kinda feel like an idiot b/c it's not happening. Anyways, I'll keep checking the oil and post if there's any problem. Thanks for all the input.
Well,
"Jiffy lube" may be your problem....Penz oil filter is cheap filter. If anything please stock up on the Japan made STI filter and take one in with you if you really have to have Jiffy do your work. What about your oils? what are you using? try switching brands.
Cheers.....
Cheers.....
Originally Posted by gt42sti
Well,
Cheers.....
Cheers.....
Josh
Josh,
Yes, if at all poss do the oil changes yourself and be sure to use the proper Japan made filter. There is a difference in these filters. And try the Mobil1 10/30 for summer use.
Good luck and I bet this takes care of it.
Dave
Dave
laoba
Jan 2, 2005 05:28 PM
Scooby25rs
Jan 1, 2005 09:33 PM
antdiesel3
14
Nov 30, 2004 09:35 PM
