noob question about 3/16 mod
Old Oct 16, 2003 | 11:12 PM
dashiet's Avatar
Question noob question about 3/16 mod
i have been thinking about doing hte 3/16 mod on the sti, but i have not reflashed me ecu, and it pings for about 3/4 second. do you guys think i should reflash or leave it the way it is until i get utec or xede ecu in. also is it bad i i do the 3/16 mod right now? because i am thinking that the 3/16 mod will make my car ping more. correct me if i am wrong =)
Old Oct 17, 2003 | 07:16 PM
You should get the factory reflash done before doing any future mods, as you will eventually be required to. Plus, if you were to be using an EcuTek reflash or an Xede, or any other engine management that utilizes the stock ECU, it will throw off that tuning map.
The 3/16 mod is essentially a very inexpensive manual boost controller that gives you 1-2 psi more. Search for it here and at nasioc and be prepared to wade through a lot of posts.
Old Oct 17, 2003 | 08:27 PM
dashiet's Avatar
what would happen if i dont get the ecu reflashed and take off the 3/16 mod? thanks for the reply
Old Oct 18, 2003 | 12:13 PM
Meaning have the car in the exact condition it was when you bought it? Well, nothing.
Old Oct 18, 2003 | 05:03 PM
dashiet's Avatar
lol sorry for my stupidness...
but i meant what would happen over time and what would the pinging lead to later on down the road?
btw...thanks for the input ban suvs
Old Oct 22, 2003 | 11:17 PM
Krinkov's Avatar
Originally posted by Snowy
Ok an even newer newbe question. What is the 3/16 mod? I haven't heard of this before.
check the pic. The mod is when you replace the inline coupling and "T" with 3/16" ones from any auto parts store. Im still a bit confused about how this mod is supposed to work since the brass restrictor thats tucked into the hose right in front of the turbo is WAY more restrictive than either the oem "T" or coupling, but people here swear it works
Attached Thumbnails noob question about 3/16 mod-turbo.jpg
Mobutusan
Apr 2, 2008 11:38 PM
T-Will
Jun 20, 2007 09:24 PM
doubleU RX
Apr 29, 2007 07:49 AM
