Need help with wastegate actuator arm ASAP!!
Old Jul 24, 2006 | 03:56 PM
Silverbullet04's Avatar
Car Info: 04 WRX
Has anyone done the wastegate flutter fix where you shorten the actuator arm a few turns? I have the c-clip off but i'm not sure how to disconnect the arm in order to shorten it and I don't want to mess anything up.
Can anyone help please?
Old Aug 1, 2006 | 05:31 PM
johnsm's Avatar
Car Info: 07 LMT HYDRA DOM3
Take the clip out, then uptight the bolt that’s there it was hard I had to put allot of oil on it, then tight the end of the arm.
I did 2 turns because COBB stage 2 Access point didn’t raise my PSI.
And with gate adjustment I get faster spool shows 0 bar at 2000 rpm, and about 15 psi in 3d gear.
scby blu
Jan 14, 2008 09:37 PM
Broz
Feb 24, 2004 12:16 PM
Darkstar
Sep 25, 2003 10:47 AM
East Coast WRX
Aug 30, 2003 10:30 PM
igo380
Wanted
Jun 9, 2003 10:46 PM
