Need help! Strange noise inside the engine bay...
Old Jan 11, 2007 | 01:22 PM
M4d_r3x's Avatar
Car Info: 2004 Black Subaru Impreza WRX STi
I have a 2004 Sti, it makes a strange noise when decelerate at 2-3k rpm from 4-3 and 3-2. I checked it already and most likely the problem is from the area around the turbo heat shield. Anybody havin a familiar case like this? Will it be harmful for the future?
Old Jan 11, 2007 | 01:54 PM
ipozestu's Avatar
Car Info: Broken Subarus
Do you have any idea how hard it is to diagnose a noise through text? What you are probably hearing is the deceleration noise. All subarus make it in one way or another. Typically if you have a noise that will cause you a problem. You won't even have to ask if it will cause problems you'll know. Have fun.
Old Jan 11, 2007 | 02:09 PM
M4d_r3x's Avatar
Well, the noise is more like rattling. Somehow, there's metal vs metal noise. I don't feel any power loss or anything but it's just annoying.
Old Jan 12, 2007 | 08:20 AM
billg's Avatar
Car Info: 2005 WRX STI
It's sounds like the same problem I had. It was a metallic rattling sound between 2-3K rpm. It was related to welds coming loose on the heat shield. I took it to GST Motorsports in Hayward, formerly associated with Gruppe-S, and it was one hour labor to re-weld it and stop the problem. Have them check it out. See gstmotorsports.com.
Old Jan 12, 2007 | 11:24 AM
SubyN00by's Avatar
do you have an aftermarket downpipe? Cuz a friend of mine bought one and installed it, and since it was a cheap one, was rattling against the firewall during deceleration...
subie4life
Nov 17, 2011 10:41 AM
mothman331
Aug 21, 2007 07:57 AM
kappaWRX
Apr 4, 2007 10:55 PM
wrxnrd
Oct 29, 2004 09:56 PM
VitaminWRX
Nov 1, 2003 12:58 AM
