Need help on hp or 1/4 est
Old Oct 2, 2005 | 07:40 AM
SilverRex04's Avatar
Car Info: 04 Sti swap, VF22 18psi, 255l fule pump,ecutek 93 oct, Full exhaust TXS, Sti ra gears, much more...
Question Need help on hp or 1/4 est
Whats up, I have an 04 wrx with an sti motor swap, 255l fuel pump, vf 22 18psi, 565cc ing, uppipe, 4" downpipe and TXS cat back, ecotek tuned 93 oct.. And a 5 speed sti v6 type ra gearset. I have'nt been to the dyno yet, but im looking to get a few 1/4 mile runs in next week. Anyone have a similar setup with times or an estimate? Thanks.
Tom
Old Oct 2, 2005 | 11:30 PM
depdivr's Avatar
Car Info: 2005 Black WRX STI
Tom
You have done a ton of work to never have had the car on a dyno! By "ecotek", I assume you mean Ecu-Tek? If so, you did need to have a pro tune the ecu... did you do a mail in reflash? I assume you did because most other vendors who can tune with the Ecu-Tek reflash also have a dyno for you to put the car on.
18 psi on an STI motor will probibly give you about 285 whp. You might pull a sub 13 quarter mile - thats only going to happen if your a good driver. Most likely you will pull 13.2 or so at 104 mphish.
Your set up is kinda interesting with some things that don't add up. I hope I am wrong.
Old Oct 3, 2005 | 12:39 AM
apssti's Avatar
tuning is everything my friend...heheh
Old Oct 3, 2005 | 05:08 AM
oh it was tuned by the top subaru technician on Long Island this guy Dave Brown hes the one who helped build my car. Thanks guys for ure input. Tom
so steezy
Jan 27, 2010 02:50 PM
unstble
Mar 21, 2008 09:09 AM
SilverRex04
Sep 30, 2005 10:31 AM
.:: 808 STi ::.
Jul 16, 2005 11:08 AM
killaho
Jun 15, 2005 05:13 PM
