Need help. Car overheating (codes)
Old May 11, 2013 | 12:17 AM
albertowrx916's Avatar
Car Info: 2004 subaru wrx
So I bought an 06 wrx all stock beside the radiator. It ran fine at first but it started overheating. It went up to about 3/4 on the temp gauge. So I decided to do a coolant flush. I flushed the system and the coolant was super dirty. I put new coolant in the system and I started to burp the system. All it did was pour massive amounts of coolant from the top reservoir tank (near turbo). The fans turned on but it did not suck any coolant from the main reservoir tank. At first I thought it was the thermostat so I took it off and it still overheated. Also it started smoking from the top reservoir tank ( don't know if its normal). Then my check engine light turned on and the cruise light started flashing. I pulled the codes p0483(control fan rationality) and p0457(Evap emission control system leak cap loose/off. Now I'm thinking it might be my water pump. Or I'm dreading head gasket but I have no coolant in oil or oil in coolant nor white smoke from exhaust. Any ideas?
Old May 11, 2013 | 11:22 AM
Bump
Old May 11, 2013 | 03:09 PM
Please i need advice!
Old May 11, 2013 | 04:34 PM
geargone9's Avatar
I'm assuming many have read your problem and are stumped... If you say there's no smoke from the exhaust and your oil is fine I'd say water pump sounds like as good a guess as any. How many miles are on your car?
Old May 11, 2013 | 04:39 PM
geargone9's Avatar
Sounds random but have you pressure tested your radiator?
Old May 11, 2013 | 04:42 PM
1JavaBlk_in_Sac's Avatar
Car Info: $2000 hawkeye
do compression check
Guillermo
14
May 4, 2015 02:18 PM
edzwrx2
Mar 4, 2008 08:42 PM
adj789
Nov 16, 2003 03:29 PM
