My next project begins....
Old Aug 18, 2004 | 12:24 AM
Krinkov's Avatar
....and I do have alot of them
hmm, another VF turbo, meh...
Krinkov's Avatar
waitaminute, whats this!
Old Aug 18, 2004 | 12:25 AM
Krinkov's Avatar
VF37 twin scroll
Old Aug 18, 2004 | 12:31 AM
Krinkov's Avatar
in case you've never seen inside one, without the twin scroll turbine housing the, it looks basically like an RHF55 cartridge, in this case about a VF30, as a matter of fact I'll bet you could even put a mount a VF22 up to this turbine housing. Im sending this off to Deadbolt tommorow to get their "PE" wheel upgrade, which will turn this basically into a PE1825
Old Aug 18, 2004 | 01:19 AM
soundwave's Avatar
more than meets the eye
Car Info: ?
awesome, can't wait to see pics of it installed
Old Aug 18, 2004 | 03:20 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Why are you posting this here?
Move it, please. You know where...
Old Aug 18, 2004 | 09:15 PM
Krinkov's Avatar
do'h, habit I guess
anyhow, talked to Jerry at deadbolt today, will most likely be machining the VF37 turbine housing to fit a VF22, also with the PE compressor wheel upgrade, would like to see 325whp on pump gas and spool like my VF34 , we'll see!
Old Aug 18, 2004 | 10:57 PM
qwk_wrx's Avatar
Car Info: 05' Evo 8
ahhh thats bad *** jeremy...
Old Aug 21, 2004 | 06:53 AM
mtnbiker4life99's Avatar
Car Info: wheels
i live my life a quarter pounder at a time. for that 500 calories or more, im free. you're lucky you didn't blow the seams on your burger box.
Old Aug 21, 2004 | 07:57 PM
Krinkov's Avatar
Originally Posted by Groove1797
I would read this forum first before starting! The VF37 was designed to use a 2.0l motor in twin-scroll. The Vf37 will be a constricting turbo on a 2.5!
http://forums.nasioc.com/forums/showthread.php?t=552016
not quite.
Ive actually posted to that thread as well, my screen name there is Invisiguard.
The VF37 is basically a VF30 in a twin scroll turbine, if you search for my other posts you will find a 7 page thread about using a VF30/34 on the STI where I show the turbos side by side with our stock VF39, the 30/34 are basically the same turbo as our stock 39 with the 30/34 having a larger P18 turbine compared the the 39s P17 turbine. So indeed, a regular VF37 would not give much more over a VF30/34 except better spool, this is why Im using a VF 22 with PE wheel in it. this will basically make it a PE1820 twin-scroll(PE1825 to those who know )
So you really cannot compare the set up Im going to have when Im done with the setup Anthonys running since the only thing we will have in common is the VF37 turbine, it would be like comparing an 18G to an FP Green because they both use a TD05 turbine
Old Aug 30, 2004 | 12:32 AM
Group B's Avatar
Dahveed aka Robin Hood
This is going to be really interesting, I'm dying to see the results!
Old Aug 30, 2004 | 12:20 PM
stimul8n's Avatar
Jeremy, PM me your telephone # so i can call you about that UTEC. i "should" be able to get mine by weeks end.
Old Aug 30, 2004 | 10:53 PM
Krinkov's Avatar
hot dog! PM sent
