Intake Installed
Old Jan 10, 2007 | 08:32 PM
impreza-tux-121's Avatar
Car Info: 2006 Impreza WRX Sti/Hawkeye
Exclamation Intake Installed
Currently The Engine Light is on and Cruise Control is blinking. OBDII check and system code says Running Rich. I know bad. But I like the sound. Faster Spool up. Stock set-up is so complicated you get nothing out of it. SOMEONE GIVE ME THE CONS?
Old Jan 11, 2007 | 01:39 PM
highwayman's Avatar
Car Info: 06 STI
Complicated? You pop the lid off & insert a new panel filter, am I missing something. Cons theres been a billion posts on this, a search will find 'em for you.
Old Jan 13, 2007 | 02:33 AM
06grayrex's Avatar
Car Info: 06 WRX TR Cobb stage 1, Perrin crank pulley, SPT intake w/shield, grounding mod, fog light mod
what intake do you have?
Old Jan 13, 2007 | 06:26 AM
ipozestu's Avatar
Car Info: Broken Subarus
Yeah what intake are you running?
Old Jan 14, 2007 | 05:16 PM
its a POWER RADER
Old Jan 14, 2007 | 11:11 PM
ipozestu's Avatar
Never heard of it, take it off and put thew stock air box back on. Or pick up a SPT intake
Old Jan 15, 2007 | 11:44 AM
doesnt a SPT intake still trick the sensor no matter what?
Old Jan 15, 2007 | 08:42 PM
06grayrex's Avatar
No it is designed to have the correct pipe dia. and maf position to not affect the readings. The only intakes that I have found to not cause any problem are K&N, Cobb, SPT. Now there may be a couple more that I don't know, but those three are safe ones to run if you want to use one. I should be recieving my spt intake w/ heat shield in a couple of days. I'll let you know what I think. I know it will not add a lot of power but any is better than nothing and being a big fan of ps2's gt 4 so I like the sound it will make.
Old Jan 16, 2007 | 09:15 AM
PghRedBean's Avatar
Car Info: I ride
Stick with SPT or Cobb. mixed reviews on the K&N. I have the SPT and have noticed 2 things:
1) smoothed out the notchy acceleration I was experiencing in my 06 Wagon.
2) Great bpv sound.
Old Jan 16, 2007 | 08:37 PM
06grayrex's Avatar
2) Great bpv sound.
Good to know because I should be receiving my spt intake w/shield tomarrow. I can't wait!!!!!!!!!
Old Jan 17, 2007 | 09:30 PM
06grayrex's Avatar
I got the SPT intake w/ heat shield today and installed it. It did made difference on hp and tq especially combined with light weight crank pulley that I installed yesterday. The car did hesitate when stepped on the pedal right after starting the car, but after letting it warm up while I checked the clamps and for leaks the hesitation started to go away (probably b/c th ECM is adpting). After driving the car I could tell the ECM is relearning but the more a drove the car the better it felt. The sound is great too. I would recomend the intake to anyone... More power, smoother through the rpms, and better sound, no CELs, whats not to like.
Old Oct 22, 2007 | 09:47 PM
Dezs_STi's Avatar
Car Info: Impreza Sti 2007
I just installed the SPT intake and i found that when i went for a test drive the car would bog down heavily on the top end 6-7k rpm. Is this what you experienced when you first installed it? I checked it over a few times to make sure i didn't forget something but it was fine.
Old Oct 22, 2007 | 10:29 PM
03_Impreza_Al's Avatar
I had a perrin filter with deleted snorkel for a while now i'm running an Injen CAI w00t.
Old Oct 23, 2007 | 10:11 AM
charlesj's Avatar
Staff Member
Car Info: 06 STI
Used the APS with no tune and it worked just fine with no downsides. Added a little power, mostly do to increased boost. Odd that that one intake gave you problems. Must have been improperly sized.
Old Oct 23, 2007 | 12:49 PM
ipozestu's Avatar
Did you bother resetting the ECU? Was it cold out? You could be pegging your MAF.
