Initial 06 WRX Dyno Results
Old Oct 13, 2005 | 05:45 PM
gruppe-s's Avatar
Hey all,
We finally got an 06 WRX in today to do some testing. Here are some dyno and AFR graphs for you to compare. This car was completely stock.
1) 06 WRX Dyno Graph
2) 06 WRX AFR
2) 05 WRX VS 06 WRX (both stock)
Mike, our tuner, had the following to say:
"It appears that because this car is running pig rich 9.9:1 afrs we should be able to make 25whp just in tuning and while also improving the overall curve. Something else of note is that the MY06 has uses a closed loop switch over that started in MY04 (due to restrictions that manufacturers have to adhere to with the exception of one vehicle in their lineup; Subaru picked the STI to be exempt so the WRX, Legacy, Baja and FXT all have to adhere to the closed loop parameters). With tuning, we can remove this switch point or speed it up (I would recommend a little of both) as I can safely say all MY04+ cars knock from time to time with the onset of boost and lack of fuel due to still running in closed loop."
-Geoff
Old Oct 14, 2005 | 08:25 AM
depdivr's Avatar
Car Info: 2005 Black WRX STI
Originally Posted by gruppe-s
Hey all,
2) 06 WRX AFR
-Geoff
Cool graphs.
Be careful with the knock... my STI does not knock. Don't let anyone tell you its ok for your engine to knock. Also, you can tune to get some hp by leaning the mixture (all good tuners can do this) but make sure your injection system can handle it. Upgrade fuel pump, rails and injectors so that you can run closer to the line without crossing over it. Finally, get an EGT gauge. If you see a spike above 1400 you may be running too lean. Mine hovers between 400 (idle) and 1200 WOT.
Old Oct 14, 2005 | 08:57 AM
gilmore25's Avatar
Car Info: 05 LegacyGT,06 Black STI Will be home Soon
What do Stock STI's put down on this dyno??? Also how much boost was the car running??
Old Oct 14, 2005 | 09:05 AM
c0neHead's Avatar
Car Info: 2006 Lotus Elise
This is my car. The car is completely stock and is running stock boost - 13.5 PSI. It has 1200 miles thus while the break-in period might be behind the full settlement of the engine might not occur before 2-3k miles.
Old Oct 14, 2005 | 10:13 AM
gilmore25's Avatar
Nice Car are you going to get some 1/4 times soon?
Old Oct 14, 2005 | 10:31 AM
c0neHead's Avatar
I am not really into drag racing but I can give you my Thunderhill lap time instead in about a month.
Old Oct 14, 2005 | 12:55 PM
gruppe-s's Avatar
Stock STi's put down around 215-225whp on our dyno. The 06 WRX was running stock boost.
Thanks,
Preston
Old Oct 14, 2005 | 01:14 PM
gilmore25's Avatar
Thanks,
Preston
Thanks Preston.. Do you think you'll have numbers on just a reflash anytime soon???
Old Oct 19, 2005 | 12:25 AM
seansrt4's Avatar
Car Info: srt4
Hey all,
2) 06 WRX AFR
-Geoff
well i posted in the srtforums.com and all the wrx people are flippin out saying that vishnu dyno'd a stock 2006 wrx at 200hp and 234 tq... any ideas how they got this?
Old Oct 19, 2005 | 12:57 AM
4080wrx's Avatar
easy not all dynos are created equally.........different brands will yield different results.....different conditions will yield different results.....hope this answers your question
Old Oct 19, 2005 | 04:13 AM
c0neHead's Avatar
Also dyno calibration makes a difference.
Old Oct 19, 2005 | 09:54 PM
seansrt4's Avatar
Car Info: srt4
such as sae correction? any conditions u know of that would make it run leaner?
Old Oct 20, 2005 | 04:54 AM
bpang1's Avatar
Car Info: '04 WRX Wagon
Wow...that's a huge difference!
Makes me really want an '06...only problem is that I can only transfer half of my aftermarket parts to the new car
At least I can take all my expensive stuff like TBE, rims (I think...right? 5x100 bolt pattern?), BOV (ha ha you bet your anus), and sounds. OK I guess that isn't half but the TBE and Rims are the most expensive that I have...yeah I suck.
3rdeyevisual209
59
May 20, 2007 05:57 AM
Kostamojen
Aug 13, 2004 07:19 AM
GameOver
Jun 13, 2004 02:00 AM
sponaugle
Feb 24, 2003 09:28 AM
WRX-Hellfire
Jan 16, 2003 09:13 AM
