I'm LEAKING...
Old Dec 18, 2004 | 04:38 PM
NeoTrunks's Avatar
Car Info: 05' STi (Aspen White/Gold wheels) aka "Tenshi". Stock for now. Evo...What EVo?
I'm LEAKING...
Ok, I know I been going on about the trans and 3rd gear...today after driving around and then washing it...I found that its LEAKING. I found it in the garage before I drove the car in. Its a small puddle near the front and it is a clear almost pink oil. I was thinking power steering.
Last edited by NeoTrunks; Dec 18, 2004 at 07:24 PM. Reason: Ranting...This Student Doc needs sleep...
Old Dec 18, 2004 | 07:19 PM
NeoTrunks's Avatar
Actually what I was asking is are there any other fulids that it could be other than Power Steering? This is my first STi. I will take a closer look in the morning. Thanks.
Old Dec 18, 2004 | 07:45 PM
Wingless Wonder's Avatar
Have you put the car up on jackstands to take a look underneath? If it's pink, that rules out engine oil or radiator coolant. The power steering pump is driven off the front of the engine so it should be relatively easy to spot if the leak originates at the pump or one of the hoses.
If in doubt let the dealer look at it under warranty.
Old Dec 19, 2004 | 06:15 PM
Group B's Avatar
Dahveed aka Robin Hood
also manual tranny fluid really stinks
Old Dec 20, 2004 | 06:10 PM
NeoTrunks's Avatar
I took it to the dealer and they showed me where it was leaking. I was right it was power steering, but they didn't have the part and sent me home. They will call when they get it, but I hope the small fitting was it. Thanks for the replys.
Old Dec 20, 2004 | 10:56 PM
Krinkov's Avatar
yeah my PS has leaked since I installed new rack bushings, I've had to order a new harline since you cant just replace the end fittings since their held on by flared ends.
Old Dec 21, 2004 | 07:01 AM
Group B's Avatar
FWIW my PS pump has been really noisy since new, and is starting to seize up.
I have to get it in the dealer soon...
InfamousDX
Jun 25, 2003 09:15 AM
InfamousDX
Jun 20, 2003 02:58 PM
minisiu
May 22, 2003 10:52 PM
spdkills
Mar 10, 2003 08:31 PM
