ihi vf34 turbo question (do I need STi 'pinks' for an '06 WRX?)
Old 10-19-2006, 06:16 PM
wrecks43's Avatar
Car Info: 2006 wrx
i have a stock 06 and i want to put the vf34 turbo in it i just need to know do i need new fuel injectors or should i upgrade??
wrecks43 is offline
Old 10-19-2006, 06:41 PM
fenderstrat066's Avatar
Car Info: 2004 Wrx
Yes you will need new, larger injectors, as well as an upgraded fuel pump. Also you have to tune your ECU once everything is installed.
fenderstrat066 is offline
Old 10-19-2006, 07:05 PM
1sicwrx's Avatar
You will need the STi pink injectors, Walbro fuel pump and engine managment, such as Accessport, I also would recommend a protune. Gruppe-S.com is selling VF34 turbo packages for pretty cheap.
1sicwrx is offline
Old 10-19-2006, 08:26 PM
Superglue WRX's Avatar
1.) Disregard the above posts, they either misread your question, or just don't know any better. The 06 injectors flow MORE than the JDM STI "Pinks".
2.) You are to read this link and continue to research how to modify the 2006-07 model WRXs
http://forums.nasioc.com/forums/show...light=06+pinks
Superglue WRX is offline
Old 10-19-2006, 08:39 PM
Car Info: 2004 Wrx
ok first off i never said get pinks, and second of all stock wrx injectors cannot handle a vf34...
Old 10-19-2006, 09:11 PM
3rdeyevisual209's Avatar
Car Info: ur mom crazy
dude! you dont need larger injectors. 06's injectors are about the same as pinks. why dont you go 18g or 20g instead of a vf34? vf34 is too small for 2.5(06's)
3rdeyevisual209 is offline
Old 10-19-2006, 10:26 PM
Originally Posted by fenderstrat066
ok first off i never said get pinks, and second of all stock EJ205 wrx injectors cannot handle a vf34... but EJ255 injectors on the 2006 WRX provide plenty of flow for a VF34
*Fixed
Old 10-19-2006, 10:33 PM
1sicwrx's Avatar
My bad, I was under the impression he was driving a 02-05 WRX.
1sicwrx is offline
Old 10-19-2006, 10:59 PM
wrecks43's Avatar
Car Info: 2006 wrx
i know about everythign else i just need to know how much the tuning is going to cost, and will i be able to drive to the place if i install like the turbo and everything else dont feel like typing it??/
wrecks43 is offline
Old 10-19-2006, 11:51 PM
Depends on where you live, assuming you already have an engine manegment system, a dyno tune usually starts at ~$200 per hour. Maybe a little more, maybe a little less. A set up like yours shouldn't go more than 2 hours at the most.
Ask around for good shops in the socal forum. Those peeps should be able to point you in the right direction.
Old 10-19-2006, 11:54 PM
I hear ya, all of those FAQ answers that are so engrained in our heads got ruined by those dang 06 models.
I got your back
Old 10-20-2006, 01:00 PM
1sicwrx's Avatar
I got your back
LOL! Thanks dude.
1sicwrx is offline
Old 10-20-2006, 01:07 PM
Car Info: 2004 Wrx
i will say the vf34 isnt a very good turbo in my opinion. The Mitsubishi turbo's 16g, 20g...have better flow rate and if you order from Deadbolt they give you free rebuilds for life! A vf34 is not too small for a 2.5L wrx though, the STI has a vf39 which is even smaller...It really depends what your looking for. If you want lots of low-mid range power get a 16g, 18g for more mid-top end, and a 20g is an awsome highway puller.
Old 10-20-2006, 09:21 PM
Krinkov's Avatar
for everyone here who hasnt heard, the 06+ wrx uses 560cc top feed "Blue" injectors
https://www.subarugenuineparts.com/p...oducts_id=1066
lucky bastids
and yeah, unless you can get a sweet deal on a used VF34, I would take a 16G over one for the price
http://linux.forcedperformance.net/m...egory_Code=WRX
Krinkov is offline
Old 10-26-2006, 09:05 AM
Mr. Furley's Avatar
Car Info: MOPAR Baby!! yeeaaaahhh
I got a vf39 for $300.... got me to a 12.90 1/4 with a stock intercooler.... ALL YOU NEED is the turbo, gaskets, accessport, exhaust, and a bigger intercooler. You DO NOT NEED injectors or a fuel pump.
Mr. Furley is offline
Quick Reply: ihi vf34 turbo question (do I need STi 'pinks' for an '06 WRX?)
