I/C Spray Light on dash
Old Nov 3, 2004 | 11:11 PM
aloose's Avatar
Car Info: 2002 Sooby WRX (not runing right)
LOL no drinking water has minerals, the reason you use distilled water is the minerals from tap/drinking water will build up inside the pump, hoses, bottle, and sprayer. and when that happens you get no more IC spray. which means no more cool intercooler, which means you go slower, and thats not what we want now is it? so use "DISTILLED WATER" kk thx plz pull thru to next window~
Old Nov 6, 2004 | 01:32 AM
beanolo's Avatar
Car Info: Skeet.
haha.. funny
Old Nov 12, 2004 | 10:56 AM
Ditchhanger's Avatar
Staff Member
Car Info: 2001 RSTi Widebody
It's also to prevent the aluminum from rusting as well as other components...
Old Nov 16, 2004 | 02:07 PM
monsterboy's Avatar
Car Info: 04 STI
Talking
Distilled water doesn't have minerals in it. So when you're spraying your intercooler and that water evaporates it doesn't leave stuff on there that could corrode the intercooler. Yes the intercooler is aluminium, but there are so many things in tap water that aren't even in rain water which will cause corrosion(chlorine) and there are higher levels of others which exacerbate the condition.
Old Nov 19, 2004 | 08:02 AM
Nick Koan's Avatar
Car Info: Legacy GT
Originally Posted by AriAllen
Ok, this one sounds reasonable, but as far a clogging the hoses... come on.... have your winshiled wipers ever clogged up on you? do you use de-ionized water there?
I do use distilled when I can't find washer fluid.
Old Nov 19, 2004 | 10:46 AM
MVWRX's Avatar
Car Info: '05 Crystal Grey Metallic WRX Sport Wagon
Aluminum can't rust...it's already coated with a layer of aluminum oxide ('aluminum rust') because air 'rusts' aluminum in less than a few seconds. Deionized, or distilled, water (they're basically the same thing) will make it harder for iron and steel to form iron oxide, which is rust. Compared to tap water I mean.
Old Nov 19, 2004 | 10:47 AM
MVWRX's Avatar
wait a minute so you drink , but o uwont put it in your car?
What about bottled water, same thing right?
The stuff that's in tap and drinking water can be good for life (except the chlorine and a few other things that they try to filter out...); but very bad for build up in lines like for an I/C sprayer.
Old Nov 19, 2004 | 10:49 AM
MVWRX's Avatar
Old cars do have problems with clogged windsheild wiper hoses. Also, with wipers you usually have cleaner in there with the water which, gasp, cleans the hoses as well as your windsheild.
dyepball1
Aug 30, 2006 06:33 PM
huck
Oct 10, 2005 02:36 PM
willl
Aug 11, 2005 11:44 AM
zillig04
Mar 24, 2005 01:02 AM
