how much PSI
Old Mar 26, 2004 | 08:44 PM
philioWRXman's Avatar
Car Info: 1998 Chevy S10... lowww
how much PSI
how much PSI does the new STi putout stock?
sorry for the noob question.
Old Mar 26, 2004 | 08:54 PM
~14.5 psi
Old Mar 28, 2004 | 10:10 AM
Rocket Man's Avatar
Car Info: it's nice
Red face
burp.
Old Mar 28, 2004 | 08:07 PM
Rocket Man's Avatar
Car Info: it's nice
oops. Sorry. About .12
Old Mar 29, 2004 | 12:31 AM
That's kPa not bar.
.12 bar is less than 2 psi.
.12 kPa =~16 psi.
at 14.5 pounds, how much boost can you max out at? I can't bring it above 12.5 bars. Normal?
Not sure what you mean. 14.5 psi is the measurement for boost... that's what it is, 14.5 pounds. I would guess that max safe boost on the VF39 is ~15.5-16 psi, but I don't have that turbo personally.
Old Mar 29, 2004 | 09:05 PM
Rocket Man's Avatar
Car Info: it's nice
Originally posted by BAN SUVS
That's kPa not bar.
.12 kPa =~16 psi.
thanks. How does kPa translate to psi and bars?
(sorry we don't have a nobie forum).
Old Mar 30, 2004 | 08:44 PM
raje7's Avatar
Car Info: 2004 sti
if you noticve where you start the boost from on the negative side youll see why same on mine alli can figure
Old Mar 30, 2004 | 09:07 PM
asianboy101's Avatar
Car Info: sti wrb
you will max boost at 18.6, then fuel cut will kick in and you will get an cel. assuming you have an sti
Old Apr 1, 2004 | 06:50 PM
Mach5WRX's Avatar
Angry Dan
Car Info: 05 Evo VIII
I make around 1.1 bar
Old Apr 3, 2004 | 05:32 AM
Hummer's Avatar
Car Info: STi Stage 1
My max boost with the Xede is 16.5 psi. Detonation generally occurs over 17 psi.
Old Apr 8, 2004 | 10:11 PM
Originally posted by Rick99gt
I am currently looking into adding a dual stage boost controler to my wifes xt for when I drive it on the weekends. Since the engines are both 2.5, Would it be safe to bump it to 16lbs psi, I beleave stock is 11.5. Only other mods i plan on doing is k&n and silencer removed
thanks
Rick C
No, that is very not safe. The XT turbo is much too small to go that high on boost. If you can't afford a reflash, don't mess with boost on a car as sophisticated as a modern Subaru.
lost
Jul 20, 2004 12:23 AM
jhong567
Dec 26, 2003 06:18 AM
feel the boost
Nov 5, 2003 10:36 PM
04.Sti
55
May 21, 2003 02:35 PM
