how much boost can be run on my STI EJ25T
Old Oct 5, 2003 | 10:09 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
The car already pings as is. Leave the boost alone until you get engine management.
Old Oct 5, 2003 | 12:51 PM
Get rid of the intake too. If it is leaning out the car, you'll ping even worse.
Old Oct 10, 2003 | 09:00 AM
Randman's Avatar
Just wondering, what is the stock boost on the STi?
Old Oct 11, 2003 | 08:42 AM
Magish's Avatar
I heard 15psi but I may be off a tad bit.
Cheers
-Jeff
Old Oct 11, 2003 | 10:58 PM
It's typically about 15 psi. Slightly higher than a WRX.
Old Oct 12, 2003 | 10:05 PM
WRX peaks at 1 bar, or 14.7 psi.
Old Oct 15, 2003 | 09:12 PM
adamRmr's Avatar
Car Info: WRX STi black/Gold rims
1 bar =14.7 or 14.5
Old Oct 15, 2003 | 09:16 PM
adamRmr's Avatar
sorry
A measure of air pressure 1 Bar= 14.7psi = 1 atm
Old Oct 16, 2003 | 12:02 AM
Yup. I probably should have just said ~14.5 psi.
Old Oct 16, 2003 | 12:45 PM
Jgrahn555's Avatar
Sarcastic Jackass
Car Info: i drive a beater
Shouldn't have to... None the less.....
Old Oct 18, 2003 | 04:54 PM
There are 2 definitons of bar, either 14.5 or 14.7 is considered 1 bar depending on who you ask. That's why I said I should have said 14.5 psi, give or take.
