How to convert a slip ring motor into an alternator?
Old Aug 10, 2012 | 10:52 PM
Jani Raxter's Avatar
Car Info: Jani Raxter
If the motor has two rotary joint, it is a synchronous motor. It can be operated as a synchronous generator by applying the proper DC excitation fiber optical rotary joints to the slip rings, connecting a 3-phase load to the stator and turning the shaft. The motor's nameplate should provide rotor and stator voltage and current ratings.
If the motor has three fiber optical rotary joint, it is an induction generator. If DC is applied between any two slip rings, it can probably be operated as a synchronous generator, but it probably will not perform as well as a machine that is designed as a synchronous machine. The motor's nameplate should provide the stator voltage, current and frequency ratings. You will probably need to determine the rotor voltage and current experimentally.
Old Aug 11, 2012 | 12:25 AM
1JavaBlk_in_Sac's Avatar
Car Info: $2000 hawkeye
Wut?
iLoqin
Nov 30, 2009 01:00 PM
not12listen
Oct 2, 2008 06:55 PM
Paradox
13
Jan 3, 2008 10:57 PM
Imprezer
Apr 26, 2004 05:54 PM
WorldONE
Apr 14, 2004 09:27 AM
