Higher rev limit with stronger internals worth it?
Old Jun 28, 2007 | 01:11 PM
pwn's Avatar
pwn
Car Info: 09 STi, 10 Cayman S
Isn't most of our power achieved by about 6500 anyway? Would it even make sense to raise the rev limit to 8000 or 8500 and get stiffer internals and cams? I think it would be cool but I'm not sure it would be worth it. Maybe a custom tune with the built engine would make use of it?
Old Jun 28, 2007 | 01:32 PM
ImportImage's Avatar
Former Vendor
only if a larger turbo is added...would i bother with a higher rev limit. that way you get more use out of it (larger power band)
Old Jun 28, 2007 | 02:01 PM
pwn's Avatar
pwn
Yea I'm only going to be going vf-34.
Old Jun 29, 2007 | 05:51 AM
Former Vendor
then its not worth it...vf34 runs out of steam around 285-300whp...so if you were going to do cams a set of 264 would be a good combo...but honestly...not worth while to rebuild the whole motor just for 300whp...
keep it stock and simple
if your going to do cams/motor build...go big!
Old Jun 29, 2007 | 01:55 PM
midnitewrx's Avatar
^^^^ EXACTLY. go big or go home. lol... wont really need em till more WHP is needed
Old Jul 4, 2007 | 03:55 PM
BlaKKStaRR's Avatar
Car Info: WRX 2007
yeah those turbo's almost running out of breath after about 6500...go TD06+ if you want to rev that high and make alotta power
koggles
Feb 27, 2006 09:45 AM
skewbnewb
Dec 11, 2005 04:10 AM
west_minist
Jun 4, 2005 10:49 AM
WRX01CR
May 27, 2005 09:18 AM
0260B4U
Feb 6, 2004 06:12 PM
