greddy oil block adapter leak
Old Feb 13, 2007 | 06:44 PM
STiAlain's Avatar
Car Info: 07STI
ok so i got a greddy oil block adapter and its leaking where the adapter meets the oil filter...not a lot but enough to **** you off....i thought it might have been a bad o-ring on the oil filter but i just changed the oil and its doing the same thing again....any ideas?
Old Feb 14, 2007 | 02:51 AM
Wingless Wonder's Avatar
If the filter is tightened properly by hand, it shouldn't leak unless the mating surface on the block adapter isn't true (or flat). You would have to remove the adapter to check the surface with a machinist's straight edge but I don't think there's a way to fix it if the mating surface is uneven.
Black_02_WRXSTI
Jun 1, 2009 02:59 PM
VRT MBasile
May 28, 2007 07:20 AM
JackHCChen
Nov 12, 2005 09:50 PM
mike626
Jun 23, 2004 12:20 PM
