Forge Bpv Question
Old Mar 9, 2007 | 05:01 PM
suba-rulez's Avatar
Car Info: 2005 apen white sti
Forge Bpv Question
What Spring Should I Have In It. Im Finally Going To Get The Fpred. I Have A Red Spring, Blue Spring And Yellow Spring. I Belive The Yellow Is The Heaviest. The Red The Lightest.
Old Mar 9, 2007 | 06:51 PM
1sicwrx's Avatar
Can all the noobies please stop beginning every word with a capital letter.
Old Mar 15, 2007 | 08:18 AM
patty AT forge's Avatar
Car Info: several
You kind of have it backwards, the springs are rated as follows:
Green 5-15
Yellow 15-23
Blue 23-30
Red 30+
Sometimes it helps to go with the next stiffer spring on MAF cars with atmospheric valves.
Old Mar 20, 2007 | 09:10 AM
Weakness's Avatar
Car Info: 2005 Subaru WRX STi
Those numbers are 100% ... there are 2 shims inside the box so if you are a tweener of levels (16psi or so) you MAY need to use one of those since you will not be on 100% boost all the time.
kingjames_115
Dec 4, 2012 10:49 AM
NorCalDC5
Oct 10, 2011 11:13 AM
ipozestu
May 14, 2008 08:43 AM
M3-to-STi
Oct 22, 2007 07:07 AM
