engine makes interior so hot??
Old Aug 22, 2004 | 08:17 PM
Digitalfiend's Avatar
Car Info: 2005 Aspen White STi
My STi does the same thing. After running the car hard, parking it for a bit, then getting back in, it definitely feels warmer. You'll also notice very warm air coming in from the vents for a few minutes.
Perfectly normal.
Old Sep 1, 2004 | 12:07 AM
1fastGC's Avatar
Car Info: Evolution VIII
its because turbo is located right in front right of the firewall. its called heat soak..
Old Sep 1, 2004 | 12:37 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
No. Its because STi's don't have insulation that regular WRX's have. Like the floor padding and the firewall insulating material is thinner.
Old Sep 1, 2004 | 05:09 PM
kewldan's Avatar
From: Houston, Texas "Drive it like you stole it.." 13.034 @ 105.19 mph
Car Info: Aspen White 04 STI, Silver 03 RS (wife's car)
I can feel it all over the outside too.. I thought it was just my sti getting super hot, I started worrying but as far as the interior is concerned I just keep A/C on... Does anyone know if make makes much of a power difference having it on??
Old Sep 1, 2004 | 10:07 PM
meilers's Avatar
You'll also notice that the engine heats the interior air if you run just air, no A/C (or even if you vent air from outside). I never run the electric heat in my car (well, I live in Arizona, duh) unless it is genuinely cold outside, because the car's engine generates enough heat by itself.
My WRX heats the entire 2-car garage by about 20 degrees after my highway commute home. I park the car, go inside, take the trash out about 30 minutes later and the garage is like an oven!
Old Sep 1, 2004 | 10:08 PM
meilers's Avatar
It can't be as noticeable of a difference with the STI, but with my 02 WRX the A/C MURDERS my low-end power and makes the car much more difficult to shift properly.
Old Sep 2, 2004 | 12:10 AM
isr96's Avatar
Car Info: 2007 suzuki GSX-R600
i think the sti is like that for me also, even though it makes more power than the wrx. starting from a stop, i have stalled it a few times because the ac is on so it does make a difference to me.
Old Sep 7, 2004 | 01:57 PM
Br1t1shguy's Avatar
Car Info: 02' WRX
Wtf is electric heat? The only electric heat in the car is the seat warmers, vent heat runs of engine coolant, welcome to cars 101
Old Sep 7, 2004 | 05:58 PM
gdogg's Avatar
Car Info: 1973 Huevo Ranchero
no insulation. turboed subies are super fricken hot.
perfectly normal.
Old Oct 5, 2004 | 09:05 AM
Group B's Avatar
Dahveed aka Robin Hood
yeah but my WRX did the same thing...
pwn
Feb 14, 2008 09:31 PM
